I've a Huawei E3372 usb modem and works out of box when I connected in my Raspbian Strech. With others Huawei modems I needed vwdial setting up, but with E3372 seems it not use wvdial to up network interface. My problem is the following, if the sim has a pin I don't know where to configure the pin. I've try to adding the pin in /etc/network/interface like that
iface eth1 inet dhcp
  wwan-apn gprs-service.com
  wwan-pin 1234
But not work. Just work if the SIM has no PIN. The 'ifconfig' command shows same autoconfig information
eth1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
    inet 192.168.8.100  netmask 255.255.255.0  broadcast 192.168.8.255
    inet6 fe80::ccb:57c9:e52f:80f7  prefixlen 64  scopeid 0x20<link>
    ether 00:1e:10:1f:00:00  txqueuelen 1000  (Ethernet)
    RX packets 442  bytes 88172 (86.1 KiB)
    TX packets 442  bytes 63307 (61.8 KiB)
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         hi.link         0.0.0.0         UG    204    0        0 eth1
192.168.8.0     0.0.0.0         255.255.255.0   U     204    0        0 eth1
Where is the configuration file when the usb modem is setting up automatically?
Thanks
EDIT: dmesg information about modem connected
[    6.981393] usb 1-1.1.2: new high-speed USB device number 7 using dwc_otg
[    7.112560] usb 1-1.1.2: New USB device found, idVendor=12d1, idProduct=14dc
[    7.112574] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    7.112584] usb 1-1.1.2: Product: HUAWEI Mobile
[    7.112592] usb 1-1.1.2: Manufacturer: HUAWEI
[    7.178518] usb-storage 1-1.1.2:1.2: USB Mass Storage device detected
[    7.178902] scsi host0: usb-storage 1-1.1.2:1.2
[    7.249224] cdc_ether 1-1.1.2:1.0 eth1: register 'cdc_ether' at usb-3f980000.usb-1.1.2, CDC Ethernet Device, 00:1e:10:1f:00:00
[    7.249487] usbcore: registered new interface driver cdc_ether
[    8.235391] scsi 0:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[    8.235863] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    8.236833] sd 0:0:0:0: [sda] Attached SCSI removable disk
crossmax
  • 303
