I have a new Raspberry Pi 4 and Sense HAT. I've installed Raspian Buster installed via SD-card and managed to boot headless with ethernet cable connected. Power is from a USB-C cable plugged into a wall outlet. So far so good.
However, as soon as I attach the Sense HAT, the machine freezes:
  • LEDs display permanent rainbow
  • green disk activity light stops
  • pi won't connect to the network
There doesn't seem to be anything in the logs, the machine just freezes.
What could this possibly be due to?
Bruce Becker
  • 161
The problem was the display resoluton. I found the solution in this github issue:
$raspi-config
7 Advanced Options
A5 Resolution
DMT Mode 4 640x480 60Hz 4:3
Since this Pi4 is booted headless, I needed to set the display resolution.
Bruce Becker
  • 161
