I would like to emulate the exact copy of my real RPi on another virtual machine. I noticed that the only working OS to build a virtual machine is the version RPdesktop. I need the specific OS version of my raspberry pi, is that possible? I tried with converting .img of my rpi on .ISO but the virtual machine doesn't found the OS. Any suggestion? Thanks
You can relatively easily do this using Docker:
1. Download and extract Raspbian
Go to the download page and download Raspbian Lite.
Once the file has finished downloading, unzip it:
cd Downloads/
unzip 2020-02-13-raspbian-buster-lite.zip
2. Mount the image
First, create a loop device from the image file:
udisksctl loop-setup --file 2020-02-13-raspbian-buster-lite.img --read-only
It'll tell you what device it was mapped to. In my case, this was /dev/loop16.
Most distributions will now automatically mount the partitions on the device. For example, Ubuntu will mount them to /media/$USER/boot and /media/$USER/rootfs.
If your distribution doesn't do this automatically, mount the rootfs partition manually:
# 1. create a directory to mount the filesystem to
sudo mkdir /media/$USER/rootfs
# 2. show the partitions of the loop device we just created
lsblk -o name,label /dev/loop16
# 3. use the name of the `rootfs` partition (loop16p2 in my case)
sudo mount -o ro /dev/loop16p2 /media/$USER/rootfs
3. Create a Docker image from Raspbian's root filesystem
sudo tar c -C /media/$USER/rootfs . | docker image import - raspbian-lite:buster
4. Allow your computer to emulate and run ARM binaries
docker run --rm --privileged docker/binfmt:820fdd95a9972a5308930a2bdfb8573dd4447ad3
(See https://www.docker.com/blog/getting-started-with-docker-for-arm-on-linux for more details)
5. Create a Docker container from the Raspbian image
docker create -it --name raspbian_test raspbian-lite:buster bash
5. Run the Docker container
docker start -ai raspbian_test
To get out of the container, you can use the exit command.
Extra: running graphical applications
This is the same as with native docker containers.
docker create -it --name raspbian_test_graphical \
-v /tmp/.X11-unix:/tmp/.X11-unix \
-e DISPLAY=unix$DISPLAY \
xhost +local:root # tell X server to accept the connection
docker start -ai raspbian_test_graphical
Inside of the container, you can then verify that it works using:
sudo apt install -y x11-apps
xeyes
It should open a window with two eyes following your mouse pointer.
- 1,006
- 6
- 8
