What is the limit of USB devices in raspberry pi4? We have an external USB hub with its power supply and 10 devices fall off with errors.
[Wed Mar 11 09:04:43 2020] usb 1-1.3.4-port1: Cannot enable. Maybe the USB cable is bad?
[Wed Mar 11 09:04:43 2020] usb 1-1.3.4-port1: cannot disable (err = -71)
[Wed Mar 11 09:04:43 2020] usb 1-1.3.4-port1: unable to enumerate USB device
[Wed Mar 11 09:04:43 2020] hub 1-1.3.4:1.0: hub_ext_port_status failed (err = -71)
[Wed Mar 11 09:04:51 2020] usb 1-1.3.1: USB disconnect, device number 4
[Wed Mar 11 09:04:51 2020] usb 1-1.3.3.1: USB disconnect, device number 8
[Wed Mar 11 09:04:51 2020] usb 1-1.3.4.2: USB disconnect, device number 11
[Wed Mar 11 09:04:51 2020] usb 1-1.3.2: USB disconnect, device number 5
[Wed Mar 11 09:04:51 2020] usb 1-1.3.3.2: USB disconnect, device number 10
[Wed Mar 11 09:04:51 2020] usb 1-1.3-port4: cannot reset (err = -71)
[Wed Mar 11 09:04:51 2020] usb 1-1.3-port4: Cannot enable. Maybe the USB cable is bad?
these are our devices:
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
| Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
| Port 3: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
| Port 1: Dev 4, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 1: Dev 4, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 1: Dev 4, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 2: Dev 5, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 2: Dev 5, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 2: Dev 5, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 3: Dev 6, If 0, Class=Hub, Driver=hub/4p, 480M
| Port 3: Dev 12, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 3: Dev 12, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 3: Dev 12, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 1: Dev 8, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 1: Dev 8, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 1: Dev 8, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 4: Dev 14, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 4: Dev 14, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 4: Dev 14, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 2: Dev 10, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 2: Dev 10, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 2: Dev 10, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 4: Dev 7, If 0, Class=Hub, Driver=hub/4p, 480M
| Port 1: Dev 9, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 1: Dev 9, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 1: Dev 9, If 1, Class=CDC Data, Driver=rndis_host, 480M
| Port 2: Dev 11, If 2, Class=Mass Storage, Driver=usb-storage, 480M
| Port 2: Dev 11, If 0, Class=Wireless, Driver=rndis_host, 480M
| Port 2: Dev 11, If 1, Class=CDC Data, Driver=rndis_host, 480M
but they're not all here, they start to fall off as soon as the raspberries are turned on, with these mistakes:
[ 8.178187] usb 1-1.3.4.3: Device not responding to setup address.
[ 8.398015] usb 1-1.3.4.3: device not accepting address 17, error -71
[ 8.398304] usb 1-1.3.4-port3: unable to enumerate USB device
[ 8.508030] usb 1-1.3.4.4: new high-speed USB device number 18 using xhci_hcd
[ 8.618234] usb 1-1.3.4.4: device descriptor read/64, error -71
[ 8.858248] usb 1-1.3.4.4: device descriptor read/64, error -71
[ 9.048184] bcmgenet fd580000.genet eth0: Link is Down
[ 9.088046] usb 1-1.3.4.4: new high-speed USB device number 19 using xhci_hcd
[ 9.198230] usb 1-1.3.4.4: device descriptor read/64, error -71
[ 9.428223] usb 1-1.3.4.4: device descriptor read/64, error -71
[ 9.548346] usb 1-1.3.4-port4: attempt power cycle
[ 10.228014] usb 1-1.3.4.4: new high-speed USB device number 20 using xhci_hcd
[ 10.228230] usb 1-1.3.4.4: Device not responding to setup address.
[ 10.448211] usb 1-1.3.4.4: Device not responding to setup address.
[ 10.668020] usb 1-1.3.4.4: device not accepting address 20, error -71
[ 10.778023] usb 1-1.3.4.4: new high-speed USB device number 21 using xhci_hcd
[ 10.778235] usb 1-1.3.4.4: Device not responding to setup address.
[ 10.998224] usb 1-1.3.4.4: Device not responding to setup address.
[ 11.218007] usb 1-1.3.4.4: device not accepting address 21, error -71
[ 11.218353] usb 1-1.3.4-port4: unable to enumerate USB device
[ 13.208212] bcmgenet fd580000.genet eth0: Link is Up - 1Gbps/Full - flow control off
~ in a couple of hours, there will be nothing left of the devices, only such records in the log:
[74578.357750] usb 1-1.3: device descriptor read/64, error -71
[74578.577751] usb 1-1.3: device descriptor read/64, error -71
[74578.797769] usb 1-1.3: reset high-speed USB device number 3 using xhci_hcd
[74578.897763] usb 1-1.3: device descriptor read/64, error -71
[74579.117771] usb 1-1.3: device descriptor read/64, error -71
[74579.337777] usb 1-1.3: reset high-speed USB device number 3 using xhci_hcd
[74579.338051] usb 1-1.3: Device not responding to setup address.
[74579.557805] usb 1-1.3: Device not responding to setup address.
[74579.777550] usb 1-1.3: device not accepting address 3, error -71
[74579.877549] usb 1-1.3: reset high-speed USB device number 3 using xhci_hcd
[74579.877837] usb 1-1.3: Device not responding to setup address.
[74580.097806] usb 1-1.3: Device not responding to setup address.
[74580.317559] usb 1-1.3: device not accepting address 3, error -71
[74580.318877] usb 1-1.3: USB disconnect, device number 3
[74580.537575] usb 1-1.3: new high-speed USB device number 22 using xhci_hcd
[74580.637820] usb 1-1.3: device descriptor read/64, error -71
[74580.857817] usb 1-1.3: device descriptor read/64, error -71
[74581.077583] usb 1-1.3: new high-speed USB device number 23 using xhci_hcd
[74581.177816] usb 1-1.3: device descriptor read/64, error -71
[74581.397822] usb 1-1.3: device descriptor read/64, error -71
[74581.517899] usb 1-1-port3: attempt power cycle
[74582.177602] usb 1-1.3: new high-speed USB device number 24 using xhci_hcd
[74582.177895] usb 1-1.3: Device not responding to setup address.
[74582.397876] usb 1-1.3: Device not responding to setup address.
[74582.617615] usb 1-1.3: device not accepting address 24, error -71
[74582.717623] usb 1-1.3: new high-speed USB device number 25 using xhci_hcd
[74582.717902] usb 1-1.3: Device not responding to setup address.
[74582.937890] usb 1-1.3: Device not responding to setup address.
[74583.157632] usb 1-1.3: device not accepting address 25, error -71
[74583.158012] usb 1-1-port3: unable to enumerate USB device
