I am new to gpiozero. I successfully managed to make some LEDs blink, but I am struggling reading out the CPU temperature as described in the example at gpiozero.readthedocs.io.
My code is pretty short:
from gpiozero import CPUTemperature
from gpiozero.pins.pigpio import PiGPIOFactory
from time import sleep
factory = PiGPIOFactory(host='192.168.1.103')
myRes = CPUTemperature(min_temp=30, max_temp=90,pin_factory=factory)
print('Initial Raspberry Pi temperature: ' + str(myRes.temperature))
print('READY and waiting 10s')
sleep(2)
The error I receive is
[Errno 2] No such file or directory: '/sys/class/thermal/thermal_zone0/temp'
However, on the RasPi itself, I can see the mentioned device (and temperature):
pi@raspberrypi:~ $  cat /sys/class/thermal/thermal_zone0/temp
50464
What do I do wrong? How can I fix that issue? Does GPIO maybe require some additional parameter?
B--rian
Unfortunately the CPUTemperature class does not support reading from a remote Pi, even if you provide a remote pin factory.
There's an issue to add it but it's probably not a priority: https://github.com/gpiozero/gpiozero/issues/581
For now you can try doing it with pigpio itself: http://abyz.me.uk/rpi/pigpio/python.html#file_open
ben_nuttall
  • 2,471
