I'm trying to make a captive portal with apache as a server and a raspberry pi on AP mode. I have some trouble trying to make the captive portal splash, I tried all tutorials on the internet and I can't make it.
My dhcpcd.conf
slaac private
interface wlan0
static ip_address=192.168.220.1/24
nohook wpa_supplicant
My dnsmasq.conf
interface=wlan0
# Use interface wlan0
address= /#/192.168.220.1
address=/connectivitycheck.gstatic.com/192.168.220.1
address=/www.gstatic.com/192.168.220.1
       # Use Cloudflare DNS
dhcp-range=192.168.220.50,192.168.220.150,12h
dhcp-option=3,192.168.220.1
dhcp-option=6,192.168.220.1
server=8.8.8.8
log-queries
listen-address=127.0.0.1
 # IP range and lease time
My configuration for my server on apache is
<VirtualHost : 192.168.220.1:80 192.168.220.1:80>
        ServerName connectivitycheck.gstatic.com
    DocumentRoot /var/www/html/AP_mode
RewriteCond %{REQUEST_URI} !=/index.html
        RewriteRule ^(.*)$ http://192.168.220.1 [L]
        ErrorDocument 404 http://192.168.220.1
        RedirectMatch 302 /generate_204 http://192.168.220.1/AP_mode
ErrorLog ${APACHE_LOG_DIR}/android_error.log
CustomLog ${APACHE_LOG_DIR}/android_access.log combined
</VirtualHost>
thanks for your help guys!
  • edit1->
The mechanism that i'm trying to build is a page who is display as a captive portal when the user connect to my raspberry pi who is in AP mode. In that page, the user has to put some information and the information will help tha raspberry pi in the futur( the management of the information is already okey) My only problem is that my page doesnt displat anything
here you can see the logs of the requests here
192.168.220.111 - - [13/Feb/2020:06:24:00 -0400] "GET /generate_204 HTTP/1.1" 302 554 "-" "Dalvik/2.1.0 (Linux; U; Android 9; SM-G965W Build/PPR1.180610.011)"
192.168.220.111 - - [13/Feb/2020:06:24:01 -0400] "GET /generate_204 HTTP/1.1" 302 554 "-" "Dalvik/2.1.0 (Linux; U; Android 9; SM-G965W Build/PPR1.180610.011)"
how you can see, there's the request of my phone who receive a 302 response, im suposed to recive a 204 have my captivep portal splash mode displaying -maybe the iptables rules are the problem? i dont use any for the moment but all request are supossed to be redirected to my apache page
At first, make sure you have configured the raspberry pi as a Wifi hotspot and check it on other devices. If other devices can connect to the AP of your raspberry pi and they get an IP address, follow this answer.
The apache.conf is the problem. Take a look at how the Splash page of a captive portal works!
Every operating system has its own different way of detecting Internet access. The mechanism is this basically:
GET/POST http://x.com/bar.html
If bar.html == [expected content] > Open Internet
If bar.html != [expected content] > Captive Portal
If bar.html[status] != SUCCESS > No Network
Each device, also Android different manufactures, behaves differently. For example, look at the list below for different manufactures/devices:
Sony Xperia Z5:
connectivitycheck.gstatic.com:80
clients3.google.com:80
Samsung Galaxy J3 2016:
172.217.21.14:80
connectivitycheck.android.com
Samsung Galaxy J7 2015:
172.16.98.10:80
galaxy note4:
nothing!
iOS 11:
captive.apple.com/hotspot-detect.html
Windows 10:
www.msftconnecttest.com
I suggest making another apache config file for specific device/manufacture.
Create a directory for android in apache directory:
cd /var/www/html/
sudo mkdir android
Create a simple index.html file that is going to appear on the splash page of the android device.
Create android.conf with touch/nano and copy the following code to create a "redirection rule" for Android devices.
sudo nano /etc/apache2/sites-enabled/android.conf
Put these lines:
<VirtualHost *:80>
    Servername connectivitycheck.gstatic.com
    ServerAdmin webmaster@localhost
    DocumentRoot /var/www/html/android
    RedirectMatch 302 /generate_204 /index.html
</VirtualHost>
Save file and exit.
Now, everything is done for android devices that are requesting to connectivitycheck.gstatic.com after connecting to a captive portal system.
Follow the procedure for other devices. Also, check THIS LINK out to get more information.
If the operating system is not important, you can install OpenWrt on your raspberry pi and then install and configure NoDogSplash as the captive portal. Check THIS LINK out to do it by OpenWrt.
Feel free to comment if you don't understand what's OpenWrt and how does it work as a Wifi hotspot and captive portal.
Mohi Rostami
  • 4,434
  • 39
