I'm building a little automated hydroponics system using a raspberry pi zero, a 5 volt relay, a pump and a soil moisture sensor from adafruit. So far everything is working, I can pull the pin to high and engaged the pump via the relay, I can get data from the soil-sensor.
I wrote a test to see if I could make it only print the readout from the sensor if the value of the read was over a certain amount and then activate it with my finger. This works great, it starts and stops if the value is greater than 600 or less than 600... However if I add the line to pull the pin to high in place of the Print function, it simply pulls the pin to high until I kill the program. What am I missing here?
My Test program:
import time
import board
from board import SCL, SDA
import busio
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
RELAIS_1_GPIO = 18
GPIO.setup(RELAIS_1_GPIO, GPIO.OUT) # GPIO Assign mode
from adafruit_seesaw.seesaw import Seesaw
i2c_bus = busio.I2C(SCL, SDA)
ss = Seesaw(i2c_bus, addr=0x36)
while True:
# read moisture level through capacitive touch pad
touch = ss.moisture_read()
if touch > 600:
GPIO.output(RELAIS_1_GPIO, GPIO.HIGH)
print("moisture: " + str(touch))
