It appears that after a kernel update happened, and rebooted for, Raspbian will no longer boot. (RPi4) After entering the (correct) encryption key when prompted, the mount fails with error:
Cannot initialize device-mapper. Is dm_mod kernel module loaded?
If I CTRL+C enough I can drop to a BusyBox shell and attempt to cryptsetup manually, but that has the same problem, even after trying modprobe dm_mod, so I don't think that the device mapper kernel module is being included in the initramfs at all.
I can remove the SD card and mount it without issue in a different Debian PC, and am able to read/write the file system, including installing packages via apt and rebuilding the initramfs. The process I'm using to do this is:
# replace /dev/sdf with your SD card block device
# make sure you do that for the two `sed` calls for "/etc/crypttab" too!
# mount
cryptsetup -v luksOpen /dev/sdf2 sdcard
mount /dev/mapper/sdcard /mnt; mount /dev/sdf1 /mnt/boot; mount -o bind /dev /mnt/dev; mount -o bind /dev/pts /mnt/dev/pts; mount -t sysfs none /mnt/sys; mount -t proc none /mnt/proc
# comment out ld.so.preload
sed -i 's/^/#/g' /mnt/etc/ld.so.preload
# crypttab needs to point to the current physical device during mkinitramfs or cryptsetup won't deploy
sed -i 's/mmcblk0p/sdf/g' /mnt/etc/crypttab
# copy qemu binary
cp /usr/bin/qemu-arm-static /mnt/usr/bin/
# chroot to Raspbian to update and rebuild initramfs
chroot /mnt /bin/bash
rm -rf /var/tmp/mkinitramfs*
apt update && apt upgrade && apt dist-upgrade && apt autoremove
test -L /sbin/fsck.luks || ln -s /sbin/e2fsck /sbin/fsck.luks
mkinitramfs -o /boot/initramfs.gz -k $(ls -t /lib/modules | tail -1)
exit
# undo damage
sed -i 's/^#//g' /mnt/etc/ld.so.preload
sed -i 's/sdf/mmcblk0p/g' /mnt/etc/crypttab
# unmount
sync
umount /mnt/{dev/pts,dev,sys,proc,boot} /mnt
cryptsetup -v luksClose sdcard
These instructions have gone through revisions to try and resolve this. Most notably the "crypttab" replacement from "mmcblk0p" to "sdf", which is only there so when mkinitramfs runs within a chroot the encrypted partition is found. Otherwise the process shows "cryptsetup: ERROR: Couldn't resolve device /dev/mmcblk0p2". (Either value give the same error when really trying to boot.)
The boot command line "/boot/cmdline.txt" refers to the encrypted partition correctly:
console=serial0,115200 console=tty1 root=/dev/mapper/sdcard cryptdevice=/dev/mmcblk0p2:sdcard rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet plymouth.ignore-serial-consoles
Kernel version going on is "4.19.97-v8+" though I've tried "4.19.97+", "4.19.97-v7+", and "4.19.97-v7l+" too.
Other than a reinstall, would you have any advice on building a good initramfs to resolve this encryption issue?
Related questions:
