For making remote ssh connection on raspberry pi 3B (os raspbian), it need to close wifi connection (to use only wired connection instead), I have found the command on SE is
sudo iwconfig wlan0 txpower off
But the problem is now I cant switch on back the wifi. I have used the code
sudo iwconfig wlan0 txpower on
it shows error,
Error for wireless request "Set Tx Power" (8B27) :
    GET failed on device wlan0 ; Input/output error.
Now what is the way to get the wifi again?
Bappa
  • 33
For making remote ssh connection on raspberry pi 3B (os raspbian), it need to close wifi connection. (to use only wired connection instead)
You can do it by ifplugd package with filling the /etc/network/interfaces out. Follow this link to do that. You can be enabled to disable wireless networks automatically when a wired cabled plugged.
However, if you are concerned about this method, you should try sudo rfkill unblock wifi before that command. Also, check this link out.
Mohi Rostami
  • 4,434
  • 39
