I am sending one integer variable from rpi to arduino. However, it is showing an error. Everything else is correct and here is the code which sends the data:-
from pubnub.pnconfiguration import PNConfiguration
from pubnub.pubnub import PubNub, SubscribeListener
import time
import numpy as np
import cv2
import serial
import RPi.GPIO as GPIO
import logging
#PubNub.set_stream_logger('recieve', logging.DEBUG)
#PubNub.SDK_VERSION
ser=serial.Serial("/dev/ttyACM0",9600) #change ACM number as found from ls /dev/tty/ACM*
ser.baudrate=9600
ser.flushInput()
GPIO.setmode(GPIO.BOARD)
#GPIO.setup(11, GPIO.OUT)
pnconfig = PNConfiguration()
pnconfig.subscribe_key = "sub-c-fefb53da-045f-11ea-a185-1a72d7432d4b"
pnconfig.publish_key = "pub-c-811efe68-1f19-4cbc-9583-473ef14f04f5"
pnconfig.ssl = False
print("Code Run")
pubnub = PubNub(pnconfig)
print("lol1")
my_listener = SubscribeListener()
print("lol2")
pubnub.add_listener(my_listener)
print("lol3")
pubnub.subscribe().channels('recieve').execute()
print("lol4")
my_listener.wait_for_connect()
print("connected")
#pubnub.publish().channel("my_channel").message('hello there').sync()
result = my_listener.wait_for_message_on('recieve')
print(result.message)
if (result.message == 'point+B'):
print("msg send")
time.sleep(1)
video_capture = cv2.VideoCapture(0)
print("video activated")
while(True):
# Capture the frames
ret, frame = video_capture.read()
print("image processing on")
crop_img = frame[0:1200, 0:700]
gray = cv2.cvtColor(crop_img, cv2.COLOR_BGR2GRAY)
# Gaussian blur
blur = cv2.GaussianBlur(gray,(5,5),0)
# Color thresholding
ret,thresh = cv2.threshold(blur,60,255,cv2.THRESH_BINARY_INV)
# Find the contours of the frame
#contours,hierarchy = cv2.findContours(thresh.copy(), 1, cv2.CHAIN_APPROX_NONE)
_, contours, _= cv2.findContours(thresh.copy(), 1, cv2.CHAIN_APPROX_NONE)
# Find the biggest contour (if detected)
if (len(contours) > 0):
c = max(contours, key=cv2.contourArea)
M = cv2.moments(c)
cx = int(M['m10']/M['m00'])
cy = int(M['m01']/M['m00'])
cv2.line(crop_img,(cx,0),(cx,720),(255,0,0),1)
cv2.line(crop_img,(0,cy),(1280,cy),(255,0,0),1)
cv2.drawContours(crop_img, contours, -1, (0,255,0), 1)
print(cx)
#cv2.imshow('frame',crop_img)
str(cx)
#cx = cx + str('\n')
write_ser=ser.write(cx.encode())
#write_ser=ser.write(cx)
int(cx)
if cx >= 450:
print ("Turn Right!")
if cx < 400 and cx > 300:
print ("On Track!")
if cx <= 50:
print ("Turn Left!")
else:
print ("I don't see the line")
#Display the resulting frame
if cv2.waitKey(1) & 0xFF == ord('q'):
break
#cap.release()
#cv2.destroyAllWindows()
console:-
Code Run
lol1
lol2
lol3
lol4
connected
point+B
msg send
video activated
image processing on
222
File "/home/pi/Desktop/Transporter codes/Final_transporter.py", line 97, in <module>
AttributeError: 'int' object has no attribute 'encode'
I tried converting to string variable but didn't work. What is the solution?
