I've been attempting to install ROS Melodic on my Raspberry Pi 4 (running Raspbian Stretch) according to the instructions on this webpage:
[https://www.instructables.com/id/ROS-Melodic-on-Raspberry-Pi-4-RPLIDAR/][1]
However, when building the catkin packages, I get this error:
[ 89%] Built target qt_gui_cpp
[ 89%] Running SIP generator for qt_gui_cpp_sip Python bindings...
  File "/opt/ros/melodic/share/python_qt_binding/cmake/sip_configure.py", line 85, in <module>
    sip_dir, sip_flags = get_sip_dir_flags(config)
  File "/opt/ros/melodic/share/python_qt_binding/cmake/sip_configure.py", line 65, in get_sip_dir_flags
    raise FileNotFoundError('The sip directory for PyQt5 could not be located. Please ensure' +
NameError: global name 'FileNotFoundError' is not defined
make[2]: *** [src/qt_gui_cpp_sip/CMakeFiles/libqt_gui_cpp_sip.dir/build.make:90: sip/qt_gui_cpp_sip/Makefile] Error 1
make[1]: *** [CMakeFiles/Makefile2:566: src/qt_gui_cpp_sip/CMakeFiles/libqt_gui_cpp_sip.dir/all] Error 2
make: *** [Makefile:141: all] Error 2
I have checked that PyQt5 is installed so I'm not sure how to fix this error.
Thanks for any help
user114149
I solved by installing this packages:
sudo apt-get install sip-dev pyqt5-dev python-sip-dev pyqt5-dev-tools
MatsK
  • 2,882
  • 22
