I installed motion by apt and run as the default configuration. I open http://raspberrypi:8080 and I can see the camera's output. I will use it over the internet and I'm worried about the security of that. I want to change all connections to https which is the least security that I can configure. How can I make all connection to https? I didn't find anything in the config file.
Thanks.
Mohi Rostami
  • 4,434
  • 39
Portrique
It's simple. There is some TLS feature for the web interface and also for the stream port.
Generate your certificate files:
apt-get install openssl
openssl genrsa -out /etc/motion/motion.key 4096
openssl req -new -key /etc/motion/motion.key -out /etc/motion/motion.crt
Now, you have created key and certificate file for the motion config file.
Motion config:
Add these lines to the /etc/motion/motion.conf:
stream_tls on
webcontrol_tls on
webcontrol_key /etc/motion/motion.key
webcontrol_cert /etc/motion/motion.crt
Restart the motion service by service motion restart and then open https://raspberrypi:8080 on a host.
Related links:
Motion configuration file manual
SSL Certificate Signing with CAcert for Raspberry Pi, Ubuntu & Debian
Self-Signed_Certificate
Mohi Rostami
  • 4,434
  • 39
