/etc/Interfaces
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.205.159
netmask 255.255.255.0
gateway 192.168.0.1
allow-hotplug wlan0
iface wlan0 inet manual
iface default inet dhcp
So i want to know if im doing something wrong as this interfaces configuration makes dhcpcd.service exit (most likely cause it configures a static ip but if thats the case why dosent it configure it correctly) doing hostname -I gives me an empty line, theres nothing in routes and ifconfig shows only lo running
UNOPARATOR
  • 153
Meow
  • 29
The network manager of Buster is working (by default) with /etc/dhcpcd.conf. Therefore, change the configuration that file as you want.
sudo nano /etc/dhcpcd.conf
Change these lines as you want:
# static IP configuration:
interface eth0
static ip_address=192.168.205.159/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
static routers=192.168.205.1
static domain_name_servers=192.168.1.251
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
Then, recover the /etc/network/interfaces by adding these lines:
Also, you have configured the /etc/network/interfaces in the wrong way. If you're going to set the IP address on 192.168.205.159 with 255.255.255.0 subnet, you can't set a gateway with 192.168.0.1 address if you are using a simple local network. The gateway should be something 192.168.205.x.
Mohi Rostami
  • 4,434
  • 39
