Hello i'm using a Raspberry pi running Raspian Jessie. I've tried updating the python version to 3.8.1 and it seems I'm having troubles running pip with it.
After i enter this line in terminal
python3.8 -m pip install Flask
I keep getting the following error
WARNING: pip is configured with locations that require TLS/SSL, however the ssl module in Python is not available.
Collecting Flask
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/flask/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/flask/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/flask/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/flask/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError("Can't connect to HTTPS URL because the SSL module is not available.")': /simple/flask/
Could not fetch URL https://pypi.org/simple/flask/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='pypi.org', port=XXX): Max retries exceeded with url: /simple/flask/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.")) - skipping
ERROR: Could not find a version that satisfies the requirement Flask (from versions: none)
ERROR: No matching distribution found for Flask
Could not fetch URL https://pypi.org/simple/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='pypi.org', port=XXX): Max retries exceeded with url: /simple/pip/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.")) - skipping
I've tried reinstalling python. And following other suggestions online. i even tried to get the ssl package manually. all with no luck. can someone please help?
