I'm developing an application using qt5.11 on Raspberry Pi 3. My code works on my laptop with ubuntu 18.xx. When I put my code on the RPi, I can compile it with the Makefile (make -j2) but when I want to launch my program I get the following message:
16:02:44: Starting /home/pi/build-VideoProcessor-Desktop-Debug/VideoProcessor...
**libEGL warning: DRI2: failed to authenticate**
**qt5ct: using qt5ct plugin**
(VideoProcessor:985): GLib-GObject-WARNING **: 16:02:55.208: cannot register existing type 'GtkWidget'
(VideoProcessor:985): GLib-GObject-CRITICAL **: 16:02:55.208: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed
(VideoProcessor:985): GLib-GObject-WARNING **: 16:02:55.208: cannot register existing type 'GtkBuildable'
(VideoProcessor:985): GLib-GObject-CRITICAL **: 16:02:55.208: g_type_interface_add_prerequisite: assertion 'G_TYPE_IS_INTERFACE (interface_type)' failed
(VideoProcessor:985): GLib-CRITICAL **: 16:02:55.208: g_once_init_leave: assertion 'result != 0' failed
(VideoProcessor:985): GLib-GObject-CRITICAL **: 16:02:55.208: g_type_register_static: assertion 'parent_type > 0' failed
I don't understand what's going on with my RPi because my code works with my laptop.
Somebody could help me? Thanks.
Mohi Rostami
  • 4,434
  • 39
G. Gilles
Try removing xserver-xorg-video-fbturbo, it causes this behavior as well as other problems:
sudo apt-get remove xserver-xorg-video-fbturbo
sudo reboot
[update 2021-04-21]
The problem returned even with xserver-xorg-video-fbturbo removed.
This post has another solution which works: Qt applications don't work due to libEGL
sudo ln -s /usr/lib/arm-linux-gnueabihf/libGLESv2.so.2 /usr/lib/arm-linux-gnueabihf/libGLESv2.so
kevind
