11
I've installed the image ubuntu-19.10.1-preinstalled-server-arm64+raspi3.img.xz on an sd card and am trying to boot ubuntu server for the first time on my raspberry pi 4.
I get to this stage in the boot and it hangs:
ubuntu 19.10 ubuntu tty1
ubuntu login: [...] cloud-init[....] Cloud-init v. 19.2-36-g059d049c-Oubuntu3 running 'modules:config' at ...
[...] cloud-init[....] Cloud-init v. 19.2-36-g059d049c-Oubuntu3 running 'modules:final' at ...
[...] cloud-init[....] Cloud-init v. 19.2-36-g059d049c-Oubuntu3 finished at ...  Datasource DatasourceNoCloud [seed=/dev/mmcblkp01][dsmode=net]
I've seen this question and tried creating the file /boot/firmware/usercfg.txt with total_mem=3072 (the file does not already exist), but it has no effect.
How should I proceed?
EDIT:
After updating /usercfg.txt on the vfat partition I advance to the previous logs, plus:
[  ok  ] Started execute cloud user/final scripts.
[  ok  ] Reached target Cloud-init target.
and I'm hanging once again.
Note there's some noise about ssh keys that I don't remember seeing before, I can give more info on that if necessary.
Mohi Rostami
  • 4,434
  • 39
Preston
  • 163
I had the exact same issue on a P3 - tried different ISOs but no joy
I was able to fix by disabling cloud init via ssh.
1) get the IP address of the Pi - I was at home so just logged onto my router and got it from there
2) in windows command line on another machine login using command :
ssh ubuntu@[ip address]
the default password is 'ubuntu'
3) you will be forced to change the password, do this
4) you will then be logged out - log back in using the above and the new password
5) when you get to the UNIX bash prompt run the command
touch /etc/cloud/cloud-init.disabled
6) exit and restart your Pi
hope this helps
enricosuarve
  • 316
