I am new to Raspberry Pi and Linux. I followed all the setup guides and have a 4" touchscreen with a case. I downloaded MPI4008-4.0inch-2019-07-10-raspbian-buster.img and flashed it to SD. I had to add wpa_supplicant.conf to the boot so it would connect to wifi on startup. Everything worked fine and wifi came up. Used rasp-config to set local and changed the password, rebooted everything fine wifi came up. Next steps update and upgrade. I used sudo apt update then sudo apt upgrade. No problems on the update but some errors on upgrade, so I did sudo apt upgrade -f. It finish no errors so rebooted now it comes up but no wifi try ethernet cable no connection. I have read many posts and tried almost everything I could find but no internet. When I try rpi-update I get:
curl: (7) Failed to connect to raw.githubusercontent.com port 443: Connection timed out !!! Failed to download update for rpi-update! !!! Make sure you have ca-certificates installed and that the time is set correctly
Update: I downloaded 2019-09-26-raspbian-buster.img and flashed it to SD. I ran update and upgrade with no errors. After reboot no wifi when the cursor is over the double red x icon it says: dhcpcd not running.
I tried to manually start dhcpcd by using sudo dhcpcd interface the output was: main: control_open: connection refused interface: interface not found or invalid dhcpcd exited
pi@raspberrypi:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet6 2601:340:c580:a350::2f6a prefixlen 128 scopeid 0x0<global>
inet6 2601:340:c580:a350:e3a6:f851:b5c:c7d5 prefixlen 64 scopeid 0x0<global>
inet6 fe80::69d2:1aa8:83f1:5e1f prefixlen 64 scopeid 0x20<link>
ether dc:a6:32:37:e4:ce txqueuelen 1000 (Ethernet)
RX packets 76 bytes 29184 (28.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 29 bytes 3793 (3.7 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether dc:a6:32:37:e4:cf txqueuelen 1000 (Ethernet)
RX packets 16 bytes 5284 (5.1 KiB)
TX packets 19 bytes 2860 (2.7 KiB)
pi@raspberrypi:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
country=US
network={
ssid="snip"
psk="snip"
key_mgmt=WPA-PSK
I am not using rpi-update anymore. Not sure how to enable the wifi. The gui has a double red x icon and I get "dhcpcd not running" when you hover on it and nothing to select when you try clicking it. When using raspi-config I get the message "could not communicate with wpa_supplicant." So how else can I enable wifi?
pi@raspberrypi:~ $ sudo iwlist wlan0 scan
wlan0 Interface doesn't support scanning : Network is down
I tried sudo ifup wlan0 did not work got an "unknown interface wlan0." So tried sudo ip link wlan0 up it did not connect to wifi but, was able to scan wlan0.
wlan0 Scan completed :
Cell 01 - Address: BC:64:4B:AF:49:07
Channel:6
Frequency:2.437 GHz (Channel 6)
Quality=70/70 Signal level=-26 dBm
Encryption key:on
ESSID:"snip"
Bit Rates:1 Mb/s; 2 Mb/s; 5.5 Mb/s; 11 Mb/s; 6 Mb/s
9 Mb/s; 12 Mb/s; 18 Mb/s
Bit Rates:24 Mb/s; 36 Mb/s; 48 Mb/s; 54 Mb/s
Mode:Master
Extra:tsf=0000000000000000
Extra: Last beacon: 40ms ago
IE: Unknown: 000846616E647769636B
IE: Unknown: 010882848B968C129824
IE: Unknown: 030106
IE: Unknown: 0706555320010B1E
IE: Unknown: 2A0100
IE: Unknown: 3204B048606C
IE: Unknown: 460571D000000C
IE: Unknown: 2D1AAD011BFFFFFF00000000000000000001000000000406E6470D00
IE: Unknown: 3D1606000500000000000000000000000000000000000000
IE: Unknown: 7F080000070200000040
IE: Unknown: DD180050F2020101840003A4000027A4000042435E0062322F00
IE: Unknown: DD0900037F01010000FF7F
IE: Unknown: DD9F0050F204104A0001101044000102103B0001031047001099A5D5D6BFEF5491AFB2B571720D3D201021001C41746865726F7320436F6D6D756E69636174696F6E732C20496E632E102300044150787810240008415078782D7878781042001253657269616C204E756D62657220486572651054000800060050F20400011011000941746865726F734150100800020004103C0001021049000600372A000120
IE: WPA Version 1
Group Cipher : TKIP
Pairwise Ciphers (2) : CCMP TKIP
Authentication Suites (1) : PSK
IE: IEEE 802.11i/WPA2 Version 1
Group Cipher : TKIP
Cell 02 - Address: BC:64:4B:AF:49:08
Channel:36
Frequency:5.18 GHz (Channel 36)
Quality=70/70 Signal level=-34 dBm
Encryption key:on
ESSID:"snip"
Bit Rates:6 Mb/s; 9 Mb/s; 12 Mb/s; 18 Mb/s; 24 Mb/s
Mode:Master
IE: Unknown: 01088C129824B048606C
IE: Unknown: 030124
IE: Unknown: 074C55532024011E28011E2C011E30011E3401183801183C01184001186401186801186C01187001187401187801187C01188001188401188801188C011895011E99011E9D011EA1011EA5011E00
IE: Unknown: 200103
IE: Unknown: 2D1AEF091BFFFFFF0000000000000000000100000000000000000000
IE: Unknown: 3D1624050400000000000000000000000000000000000000
IE: Unknown: BF0CB2018033EAFF0000EAFF0000
IE: Unknown: C005012A00FCFF
IE: Unknown: C30402C4C4C4
IE: WPA Version 1
Group Cipher : TKIP
Group Cipher : TKIP
Cell 03 - Address: BE:64:4B:AF:49:07
Channel:6
Quality=70/70 Signal level=-27 dBm
Encryption key:on
ESSID:""
Mode:Master
IE: Unknown: 0000
IE: Unknown: 030106
IE: Unknown: 050400010000
IE: Unknown: 2A0100
IE: Unknown: 7F080000000200000040
IE: WPA Version 1
Group Cipher : TKIP
Group Cipher : TKIP
Cell 04 - Address: FE:64:4B:AF:49:07
Channel:6
Quality=70/70 Signal level=-25 dBm
Encryption key:on
ESSID:""
Mode:Master
IE: Unknown: 0000
IE: Unknown: 030106
IE: Unknown: 2A0100
IE: WPA Version 1
Group Cipher : TKIP
Authentication Suites (1) : 802.1x
Group Cipher : TKIP
Now when I do ifconfig wlan0:
pi@raspberrypi:~ $ ifconfig wlan0
wlan0: flags=4098<BROADCAST,MULTICAST> mtu 1500
RX packets 8 bytes 3133 (3.0 KiB)
TX packets 21 bytes 2908 (2.8 KiB)
I have tried many times and many things still no wifi after doing updates. I reflashed the sd many times and still get the same problem.
This is what I get after update: Double red x icon, dhcpcd not running. There are no networks to chose from.
update_config=1
country=US
network={
ssid="Snip"
psk="snip"
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 458 bytes 72723 (71.0 KiB)
TX packets 22 bytes 3267 (3.1 KiB)
wlan0 Interface doesn't support scanning: Network is down
RX packets 8 bytes 1097 (1.0 KiB)
TX packets 23 bytes 3461 (3.3 KiB)
pi@raspberrypi:~ $ iwconfig
wlan0 IEEE 802.11 ESSID:off/any
Mode:Managed Access Point: Not-Associated
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
eth0 no wireless extensions.
lo no wireless extensions.
pi@raspberrypi:~ $ sudo wpa_cli -i wlan0 reconfigura
Failed to connect to non-global ctrl_ifname: wlan0 error: No such file or directory
What can I do to get wifi?
pi@raspberrypi:~ $ sudo systemctl status dhcpcd.service
● dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: e
Active: failed (Result: signal) since Sat 2020-01-18 03:07:53 EST; 1min 40s a
Process: 396 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -b (code=exited, status=0/SU
Main PID: 429 (code=killed, signal=SEGV)
Jan 18 03:07:48 raspberrypi dhcpcd[429]: wlan0: REPLY6 received from fe80::be64:4bff:feaf:490a
Jan 18 03:07:48 raspberrypi dhcpcd[429]: wlan0: adding address 2601:340:c580:a350::31e5/128
Jan 18 03:07:48 raspberrypi dhcpcd[429]: wlan0: renew in 302400, rebind in 483840, expire in 604800 seconds
Jan 18 03:07:52 raspberrypi dhcpcd[429]: wlan0: leased 169.254.1.165 for infinity
Jan 18 03:07:52 raspberrypi dhcpcd[429]: wlan0: adding route to 169.254.1.0/24
Jan 18 03:07:52 raspberrypi dhcpcd[429]: wlan0: adding default route via 169.254.1.64
Jan 18 03:07:52 raspberrypi dhcpcd[429]: wlan0: deleting route to 169.254.1.0/24
Jan 18 03:07:52 raspberrypi dhcpcd[429]: wlan0: deleting default route via 169.254.1.64
Jan 18 03:07:52 raspberrypi systemd[1]: dhcpcd.service: Main process exited, code=killed, status=11/SEGV
Jan 18 03:07:53 raspberrypi systemd[1]: dhcpcd.service: Failed with result 'signal'.
lines 1-16/16 (END)
******* FRESH DOWNLOAD *******
- Downloaded Raspbian from raspberrypi.org site.
- Used etcher to burn img to SD card.
- Added LCD-show file(LCD screen drivers from GitHub) to SD card.
- Inserted SD card into pi4 and followed startup screens. When it asked to reboot I skipped it so I could install LCD screen drivers. Used
raspi-configto setup wifi and rebooted. - Everything was working fine internet came up and was able to surf the web.
- Opened terminal and typed
sudo apt update, it worked fine. 166 files to upgrade. - Used
sudo apt full-gradehad to run it twice it errored the first time. - Rebooted the pi and now no internet connection.
- Tried to connect with the GUI no luck just get a No wireless interfaces found.
- Tried to use
raspi-configNetwork Options get message Could not communicate with wpa_supplicant.
update_config=1
country=US
network={
ssid="********"
psk="************"
key_mgmt=WPA-PSK
I also did the same steps above without using the LCD-Screen drivers and get the same end result no wifi. I have read the foundation guidelines but cannot find what to do next. Everything on the web seems several years old.
wlan0 Interface dosen't support scanning : Network is down
***** journalctl -b command used !!!!message was in red *****
Jan 22 14:41:50 raspberrypi kernel: brcmfmac: F1 signature read @0x18000000=0x15264345
!!!!Jan 22 14:41:50 raspberrypi kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
Jan 22 14:41:50 raspberrypi kernel: usbcore: registered new interface driver brcmfmac
!!!!Jan 22 14:41:51 raspberrypi kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
!!!!Jan 22 14:41:51 raspberrypi kernel: brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
Jan 22 14:41:51 raspberrypi systemd-udevd[166]: Using default interface naming scheme 'v240'.
Jan 22 14:41:59 raspberrypi systemd[1]: Starting Bluetooth service...
Jan 22 14:41:59 raspberrypi systemd[1]: systemd-update-utmp-runlevel.service: Succeeded.
Jan 22 14:41:59 raspberrypi systemd[1]: Started Update UTMP about System Runlevel Changes.
Jan 22 14:41:59 raspberrypi bluetoothd[753]: Bluetooth daemon 5.50
Jan 22 14:41:59 raspberrypi systemd[1]: Started Bluetooth service.
Jan 22 14:41:59 raspberrypi systemd[1]: Started Raspberry Pi bluetooth helper.
Jan 22 14:41:59 raspberrypi bluetoothd[753]: Starting SDP server
Jan 22 14:41:59 raspberrypi systemd[1]: Started BluezALSA proxy.
Jan 22 14:41:59 raspberrypi systemd[1]: Reached target Bluetooth.
Jan 22 14:41:59 raspberrypi systemd[1]: Startup finished in 2.663s (kernel) + 13.368s (userspace) = 16.031s.
Jan 22 14:41:59 raspberrypi kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Jan 22 14:41:59 raspberrypi kernel: Bluetooth: BNEP filters: protocol multicast
Jan 22 14:41:59 raspberrypi kernel: Bluetooth: BNEP socket layer initialized
Jan 22 14:41:59 raspberrypi bluetoothd[753]: Bluetooth management interface 1.14 initialized
Jan 22 14:41:59 raspberrypi dbus-daemon[360]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested b
!!!!Jan 22 14:41:59 raspberrypi bluetoothd[753]: Sap driver initialization failed.
!!!!Jan 22 14:41:59 raspberrypi bluetoothd[753]: sap-server: Operation not permitted (1)
Jan 22 14:41:59 raspberrypi systemd[1]: bthelper@hci0.service: Succeeded.
Jan 22 14:42:00 raspberrypi bluetoothd[753]: Endpoint registered: sender=:1.19 path=/org/bluez/hci0/A2DP/SBC/Source/1
Jan 22 14:42:00 raspberrypi bluetoothd[753]: Endpoint registered: sender=:1.19 path=/org/bluez/hci0/A2DP/SBC/Source/2
Jan 22 14:42:00 raspberrypi systemd[1]: Starting Hostname Service...
Jan 22 14:42:00 raspberrypi kernel: Bluetooth: RFCOMM TTY layer initialized
Jan 22 14:42:00 raspberrypi kernel: Bluetooth: RFCOMM socket layer initialized
Jan 22 14:42:00 raspberrypi kernel: Bluetooth: RFCOMM ver 1.11
!!!!Jan 22 14:42:00 raspberrypi bluetoothd[753]: Failed to set privacy: Rejected (0x0b)
Jan 22 14:42:00 raspberrypi dhcpcd[431]: wlan0: soliciting an IPv6 router
Jan 22 14:42:00 raspberrypi dbus-daemon[360]: [system] Successfully activated service 'org.freedesktop.hostname1'
Jan 22 14:42:00 raspberrypi systemd[1]: Started Hostname Service.
Jan 22 14:42:00 raspberrypi dhcpcd[431]: wlan0: rebinding lease of 169.254.1.165
Jan 22 14:42:00 raspberrypi dhcpcd[431]: wlan0: probing address 169.254.1.165/24
Jan 22 14:42:01 raspberrypi dhcpcd[431]: wlan0: Router Advertisement from fe80::be64:4bff:feaf:490a
Jan 22 14:42:01 raspberrypi kernel: ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms in
Jan 22 14:42:01 raspberrypi dhcpcd[431]: wlan0: adding address 2601:340:c580:a350:db34:3209:afe4:db0c/64
Jan 22 14:42:01 raspberrypi avahi-daemon[350]: Leaving mDNS multicast group on interface wlan0.IPv6 with address fe80::bcd6:d0ae:a078:5763.
Jan 22 14:42:01 raspberrypi avahi-daemon[350]: Joining mDNS multicast group on interface wlan0.IPv6 with address 2601:340:c580:a350:db34:3209:afe4:db0c.
Jan 22 14:42:01 raspberrypi avahi-daemon[350]: Registering new address record for 2601:340:c580:a350:db34:3209:afe4:db0c on wlan0.*.
Jan 22 14:42:01 raspberrypi dhcpcd[431]: wlan0: adding route to 2601:340:c580:a350::/64
Jan 22 14:42:01 raspberrypi avahi-daemon[350]: Withdrawing address record for fe80::bcd6:d0ae:a078:5763 on wlan0.
Jan 22 14:42:01 raspberrypi dhcpcd[431]: wlan0: confirming prior DHCPv6 lease
Jan 22 14:42:01 raspberrypi dhcpcd[431]: wlan0: adding default route via fe80::be64:4bff:feaf:490a
Jan 22 14:42:02 raspberrypi dhcpcd[431]: wlan0: REPLY6 received from fe80::be64:4bff:feaf:490a
Jan 22 14:42:02 raspberrypi dhcpcd[431]: wlan0: adding address 2601:340:c580:a350::dd95/128
Jan 22 14:42:02 raspberrypi dhcpcd[431]: wlan0: renew in 302400, rebind in 483840, expire in 604800 seconds
Jan 22 14:42:02 raspberrypi avahi-daemon[350]: Registering new address record for 2601:340:c580:a350::dd95 on wlan0.*.
Jan 22 14:42:04 raspberrypi systemd[1]: systemd-rfkill.service: Succeeded.
Jan 22 14:42:05 raspberrypi dhcpcd[431]: wlan0: leased 169.254.1.165 for infinity
Jan 22 14:42:05 raspberrypi avahi-daemon[350]: Joining mDNS multicast group on interface wlan0.IPv4 with address 169.254.1.165.
Jan 22 14:42:05 raspberrypi avahi-daemon[350]: New relevant interface wlan0.IPv4 for mDNS.
Jan 22 14:42:05 raspberrypi avahi-daemon[350]: Registering new address record for 169.254.1.165 on wlan0.IPv4.
Jan 22 14:42:05 raspberrypi dhcpcd[431]: wlan0: adding route to 169.254.1.0/24
Jan 22 14:42:05 raspberrypi dhcpcd[431]: wlan0: adding default route via 169.254.1.64
Jan 22 14:42:05 raspberrypi avahi-daemon[350]: Withdrawing address record for 169.254.1.165 on wlan0.
Jan 22 14:42:05 raspberrypi avahi-daemon[350]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 169.254.1.165.
Jan 22 14:42:05 raspberrypi avahi-daemon[350]: Interface wlan0.IPv4 no longer relevant for mDNS.
Jan 22 14:42:05 raspberrypi dhcpcd[431]: wlan0: deleting route to 169.254.1.0/24
Jan 22 14:42:05 raspberrypi dhcpcd[431]: wlan0: deleting default route via 169.254.1.64
Jan 22 14:42:05 raspberrypi systemd[1]: dhcpcd.service: Main process exited, code=killed, status=11/SEGV
Jan 22 14:42:06 raspberrypi avahi-daemon[350]: Interface wlan0.IPv6 no longer relevant for mDNS.
Jan 22 14:42:06 raspberrypi avahi-daemon[350]: Leaving mDNS multicast group on interface wlan0.IPv6 with address 2601:340:c580:a350:db34:3209:afe4:db0c.
Jan 22 14:42:06 raspberrypi avahi-daemon[350]: Withdrawing address record for 2601:340:c580:a350::dd95 on wlan0.
Jan 22 14:42:06 raspberrypi avahi-daemon[350]: Withdrawing address record for 2601:340:c580:a350:db34:3209:afe4:db0c on wlan0.
Jan 22 14:42:06 raspberrypi systemd[1]: dhcpcd.service: Failed with result 'signal'.
Jan 22 14:42:22 raspberrypi systemd[1]: systemd-fsckd.service: Succeeded.
