There are questions similar to this one, but I am not an expert Unix user so I really don't wanna try and break /etc/fstab while doing this. Here's what blkid tells me about my hard drive:
/dev/sda1: LABEL="X" UUID="9C4A70404A7018EA" TYPE="ntfs" PARTUUID="7d4613d7-01"
I always mount my drive at /media/pi/X, it is formatted in NTFS and I need both read and write permissions on it. The drive's UUID is 9C4A70404A7018EA and my useridis 1000. I know this post is very redundant, but I really cannot mess this up.
I've read this post from askubunto.com, so I know that a common setup is of this kind:
UUID=<uuid> <pathtomount> <filesystem> defaults 0 0
However, I do not understand some parts and would rather play it safe. Thanks in advance.
zeval
  • 35
This is the line in my /etc/fstab for a Toshiba Canvio 1 TB usb drive. Your UUID and mount points will be different.
UUID=A0027BBF027B994C /media/pi/Toshiba ntfs-3g defaults,auto,umask=000,users,rw,nofail 0 0
Michael Harvey
  • 1,410
I know you are trying to replace an automount.
fstab is confusing, the documentation for mount is somewhat clearer.
If you are happy with the way automount works I suggest you let your system automount, then issue the mount command and copy the settings.
The following is a line from my fstab. I use noauto and manually mount, but if you want to mount on boot you should use nofail
UUID=4AF49046F4903663       /mnt/SeagateNTFS     ntfs   rw,noauto,relatime,umask=22,uid=0,gid=0,nls=utf8    0   0
I would recommend against mounting in /media which is (ab)used by automount.
PS I rarely use NTFS, and you should probably use ntfs-3g if planning to write.
