I've had my RPI4 configured to boot from the network if there is no SD card inserted (for bare metal programming) but firmware update restored it back to SD boot only. So I've tried to make it boot from the network again using this procedure: https://www.raspberrypi.org/documentation/hardware/raspberrypi/bcm2711_bootloader_config.md. But I've misconfigured BOOT_ORDER setting it to 0x2 instead of 0x12. Now it does not boot from SD card at all. It boots from network fine. I have BOOT_UART option enabled and I see that it doesn't even try to boot from SD card. It tries to boot few times over network and stops, giving FATAL @ 0x80001fc2 message. The official documentation says:
The Raspberry Pi 4 has an SPI-attached EEPROM (4MBits/512KB), which contains code to boot up the system and replaces bootcode.bin previously found in the boot partition of the SD card. Note that if a bootcode.bin is present in the boot partition of the SD card in a Pi 4, it is ignored.
but it doesn't seem to be the case. Is there a way to restore original EEPROM contents? I would like to avoid desoldering and reprogramming the EEPROM chip since it would void the warranty for sure.
pvc
  • 131
Download and install the Raspberry Pi Imager on your Mac, Linux computer or Windows PC.
Use it to install a bootloader* onto an SD card.
Boot the Raspberry Pi using the SD card. The bootloader will be updated.
* In the Imager, select Misc utility images, then Bootloader, then choose one of the boot options corresponding to the boot order you prefer. Choose a storage location. Then choose Write.
The same imager can be used to install various operating systems.
Dennis Williamson
  • 1,739
Download bootloader archive from https://www.raspberrypi.org/downloads/. Unpack it on to freshly FAT32 formatted µSD card (mine was partitioned and had boot flag enabled for the partition). RPI4 should be able to boot from it and restore EEPROM contents. If it succeeds it will start to flash ACT LED rapidly. There is also some progress info outputted to its serial port during this process. recover* files from NOOBS archive will NOT work.
pvc
  • 131
