I have been working on a project that uses Pi Zeros as remote cameras. Recently, I have an application that requires them to be hardwired, so I have been experimenting with the Ethernet over USB function on the Zeros. I have it working on OS X and Linux (Ubuntu).
I followed these steps (not including the static ip): https://learn.adafruit.com/turning-your-raspberry-pi-zero-into-a-usb-gadget/ethernet-gadget
[edit]: Changed to to using the tutorial suggested in the comments, following the Ethernet gadget section. https://www.isticktoit.net/?p=1383
However, I cannot connect the Zeros to a Pi 4 via ethernet over USB. I thought it would be the same process as my Linux computer, but the Pi 4 does not show the usb0 when the Zero is plugged in.
Are there extra steps I need to take to enable the USB interface on the Pi 4? Is there a better tutorial I could be following?
My goal is to plug 4x Zeros in to the Pi 4 via USB and control them through SSH.
Here is the dmesg when I plug the Zero into the Pi4. However the cable was tested on my laptop using the Zero.
[ 176.391762] Under-voltage detected! (0x00050005)
[ 182.631705] Voltage normalised (0x00000000)
[ 189.081934] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 189.991993] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 189.992184] usb 1-1-port2: attempt power cycle
[ 191.271930] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 192.182002] usb 1-1-port2: Cannot enable. Maybe the USB cable is bad?
[ 192.182192] usb 1-1-port2: unable to enumerate USB device
After connecting to the power supply that came with the Pi4. It keeps repeating this block, iterating the device number each time.
[ 119.141654] usb 1-1.4: new high-speed USB device number 25 using xhci_hcd
[ 119.272720] usb 1-1.4: New USB device found, idVendor=0525, idProduct=a4a2, bcdDevice= 4.19
[ 119.272736] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 119.272750] usb 1-1.4: Product: RNDIS/Ethernet Gadget
[ 119.272762] usb 1-1.4: Manufacturer: Linux 4.19.75+ with 20980000.usb
[ 119.276883] cdc_ether 1-1.4:1.0 usb0: register 'cdc_ether' at usb-0000:01:00.0-1.4, CDC Ethernet Device, e2:9f:07:61:08:9f
[ 119.822601] usb 1-1.4: USB disconnect, device number 25
The pi4 power supply is 5.1V at 3.5A. As of right now I have only attempted to connect 1x Pi Zero.
