Rapsberry Pi 4 with Noobs & Rapsbian full installed. Was working perfectly, until I did an apt-get dist-upgrade. Now (after reboot) it seems the window manager is broken or not launched : symptoms, mouse can not interact with windows (move, resize, close etc. no work). Keyboard actions are not affected (Alt+F4 closes a window, e.g.)
I am willing to restart from zero, using Noobs, which I verified is working and accessible at boot time. Noobs is seeing the Rasbian - Full as "installed" and it has a chek-mark besides it.
How am I supposed to tell Noobs to zap the installed OS, repartition the card as might be necessary, download the official Raspbian for my Pi and start all over ? Un-checking the mark of the "installed" OS did nothing, and I couldn't find a way to "remove" or "uninstall", whatever they might call it.
NimbUs
NOOBS has a recovery option to trash everything you've done on your Raspbian system and start again (it gives you an unpatched system just like the day you started).
Hit or tap the SHIFT key during boot to activate the recovery menu.
https://raspberrypi.stackexchange.com/a/24855/94397
Dougie
  • 5,381
  • 22
  • 30
This is the wrong site to ask about NOOBS because few (if any) of the experienced uses use NOOBS. The general recommendation on this site is NOT to use NOOBS.
You should be able to re-install Raspbian from NOOBS by pressing the Shift key at the correct time during boot.
Did you update Raspbian BEFORE upgrade? The following command will update Raspbian.
sudo apt-get update && sudo apt-get -y dist-upgrade
