I'm writing a script to control my network interfaces. I've three network interfaces viz eth0, ppp0, wlan0. I want such a configuration that when there is no internet available on eth0, it should switch to ppp0 and when ppp0 is also down, it should switch to wlan0.
Whenever I need to switch from eth0 to ppp0, I write following command:
sudo route add default gw "IP of ppp0"
And it gets connected. But the problem is there while switching between eth0 to wlan0 and vice-versa.
Sometimes while using sudo route add default gw 192.168.1.254 eth0, I get following response:
SIOCADDRT: File exists
And interface do not switch.
I check for the route command and I got following result:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.1.254 0.0.0.0 UG 202 0 0 eth0
default 192.168.43.141 0.0.0.0 UG 303 0 0 wlan0
10.64.64.64 0.0.0.0 255.255.255.255 UH 304 0 0 ppp0
192.168.0.0 0.0.0.0 255.255.252.0 U 202 0 0 eth0
192.168.43.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
Then I've to remove all interfaces by using following command multiple times:
sudo route del default
Then after checking route again, I successfully deleted existing gateways and get this:
But the problem I faced is that, after 4-5 minutes, these gateways appears again without any changes made by me. Help me to make me understand the working of linux here. How gateway IPs are configured automatically and how can I prevent it to do so.
