Might be biting off more than I can chew with this project but I received a raspberry pi + touch screen kit and wanted to add 2 max31865 chips. Screen takes up most pins but luckily has ' extended the 13*2 Pin Socket signal Pin-to-Pin '
  • Does this mean I can reuse pin-outs ?
  • Do they keep the same address and I just pretend like there is no screen attached?
The manual came with a pin map and labeled a bunch as 'no connected' are those the only ones free to use, cant be used, or use any its just a description?
https://i.sstatic.net/pMm9f.jpg :1 Photo of Pi+extended pins, 1 Photo of screen pin map
I am very confused on how the Pi will interact with these, hoping for some guidance before I try to solder on wires and wreak it all
