According to the Pi 4 Bootloader Configuration documentation you can patch the boot ROM to preset various configuration values, and one of them is the TFTP server address using TFTP_IP (since EEPROM version 2020-04-16).
You can also configure a static IP address to avoid relying on DHCP just to reach the TFTP server.
If TFTP_IP and the following options are set then DHCP is skipped and the static IP configuration is applied.
The static IP options are CLIENT_IP, SUBNET (optional), GATEWAY (optional).
You'll need to follow the instructions at that link as they are a bit long to repost here, but the gist of it is:
cp /lib/firmware/raspberrypi/bootloader/beta/pieeprom-2019-09-23.bin pieeprom.bin
rpi-eeprom-config pieeprom.bin > bootconf.txt
# Edit bootconf.txt and set TFTP_IP=1.2.3.4
rpi-eeprom-config --out pieeprom-netboot.bin --config bootconf.txt pieeprom.bin
sudo rpi-eeprom-update -d -f ./pieeprom-netboot.bin # Flash updated boot ROM
Basically you extract the boot ROM config into a text file, edit it, then merge it back to the ROM file and reflash it.
