9
I have been using RPi4 for a while and I have found some problems playing videos on VLC and YouTube. After searching for a long time, I found that these problems can be solved by increasing GPU memory. I found that option in the Raspberry Pi configuration I need to know ,
  1. What is the maximum and minimum memory value for GPU?
  2. What is the optimum value of GPU memory?
  3. Will I face any problems if I set the value very high or very low?
Sohan Arafat
  • 1,852
  • 43
Here's the relevant part of the official docs.
Min and max:
GPU memory in megabytes, sets the memory split between the CPU and GPU; the CPU gets the remaining memory. The minimum value is 16; the technical maximum value 944 [for the RPi 4]. The default value is 64, values above 512 will not provide increased performance and should not be used.
Default values:
For Pis with less than 1GB of memory, the default is 64; for Pis with 1GB or more of memory the default is 76.
Recommended value:
The Raspberry Pi 4 3D system has it's own Memory Mangement Unit (MMU) so textures and other GL resources are not allocated from the gpu_mem but Linux system memory instead. This means that gpu_mem can be set to a lower value, so even if you are using the H264 and camera then 128MB will probably be enough.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
You shouldn't need to set it beyond the default value in the plain Raspbian /boot/config.txt. Max value is 128M.
Setting it beyond 128M can leave your Raspberry Pi 4B unbootable.
GPU memory on a RPi4B isn't used in the same way as on earlier Raspberries.
Dougie
  • 5,381
  • 22
  • 30
