So I just got a new raspberry pi 3 b+ earlier this week by RS Components and I got it working on the first day. A couple days I shut it down and later when I tried to turn it back on, it didn't all it shows is the red led indicating the power, not the green ACT light. I tried re-flashing my 16gb SD card with NOOBS again. What should I do? (I have tried The boot problems sticky . It is not hot and I have used the GPIO pins during the week.
UPDATE I have just decided to say it is broken. I may have over-voltaged it and if anyone knows if RS components does replacements can you tell me
Bryson Lee
So, it turns out I did not have enough power and I was using a lot of the pins. I also may have accidentally damaged something as well. I have decided to get a refund (which was successful) and just buy a new one from canakit. I will try to be more careful. Usually, Amazon is good with returns.
Bryson Lee
You Don't flash a SD card with NOOBS you have to format the SD card then copy NOOBS on to it.
NOTE this is harder, takes longer, wastes 1.3GB of your SD card and is almost impossible to update, which is why most of us DON'T use NOOBS
NOTE the The Boot Problems Sticky doesn't really apply to NOOBS - it is geared at Raspbian boot problems.
