I am attempting to run a PWM on a pump using rpi.GPIO using the following code:
def run_PWM_on_pump():
gpio.setmode(gpio.BOARD)
gpio.setup(8, gpio.OUT)
p = gpio.PWM(8, 0.5) #also works at 5000 frequency, 100 duty cycle
p.start(15)
time.sleep(2)
p.stop()
However, the only time this PWM results in the pump running, is by that configuration (0.5 frequency, 15 duty cycle) or any frequency at 100 duty cycle. We have tried lowering the voltage manually, and the pump does indeed run at lower voltages, but for some reason the PWM is not working as expected.
EDIT: the pump is rated for 24 volts, but we were able to get the pump to run by providing 12 volts.
EDIT2: Pump is connected to the PI via GPIO, turning the gpio pin on causes the pump to stay on until the pin is turned off. To do this, I am using rpi.GPIO's built in PWM functions/GPIO functions. No hardware PWM as far as I know is built into the board.
EDIT3: Link to the pump can be found here: https://www.usplastic.com/catalog/item.aspx?itemid=117560
Pump normally operates at 24V with <2.2A of current.
