I need to store the current IP adress of my Raspberry Pi into a file. Can someone tell me how to do this?
The goal is to create a file in /var/www/ipadress.txt with this content:
192.168.0.28
$ ifconfig
eth0      Link encap:Ethernet  Hardware Adresse b8:27:eb:7c:ce:18
          inet Adresse:192.168.0.28  Bcast:192.168.0.255  Maske:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metrik:1
          RX packets:1762 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1044 errors:0 dropped:0 overruns:0 carrier:0
          Kollisionen:0 Sendewarteschlangenlänge:1000
          RX bytes:267534 (261.2 KiB)  TX bytes:233261 (227.7 KiB)
I need the part: 192.168.0.28
syb0rg
  • 8,178
  • 38
s3bi
  • 160
I found that this command will give you the IP address only:
$ /sbin/ifconfig eth0 | grep 'inet addr:' | cut -d: -f2 | awk '{ print $1}'
To output it to a file:
$ /sbin/ifconfig eth0 | grep 'inet addr:' | cut -d: -f2 | awk '{ print $1}' > "/var/www/ipadress.txt"
syb0rg
  • 8,178
  • 38
language independent version:
ifconfig | grep -o "\([0-9]\+\.\)\+[0-9]\+" | head -n 1
or, as it was noted in another question
hostname -I
might do the trick as well.
lenik
  • 11,533
  • 37
