I am trying to set up a Raspberry Pi 4 as a wlan0 <-> wlan1 router and followed Ingo's excellent guide here:
Access point as WiFi router/repeater with additional WiFi-dongle
Having gone through all the steps on a fresh, updated Buster installation, I've not been able to make this work.
wlan1 happily connects to the internet (I am typing this on the Raspberry Pi 4 in question) and other computers can connect to the access point I set up at wlan0.
However no internet access is happening for computers connected to wlan0.
ifconfig on computers connected to wlan0 indicates that they are somehow picking up an IP address from wlan1's range instead of wlan0's DHCP range.
I'm tearing my few remaining hairs out here. Have gone through the entire process described in Ingo's answer with a fresh install of Buster.
Any help is greatly appreciated!
Additional info:
# Here is my /etc/resolvconf.conf:
resolvconf=NO
resolv_conf=/etc/resolv.conf
dnsmasq_resolv=/var/run/dnsmasq/resolv.conf
pdnsd_conf=/etc/pdnsd.conf    unbound_conf=/var/cache/unbound/resolvconf_resolvers.conf
# My /etc/wpa_supplicant/wpa_supplicant-wlan0.conf:
country=GB
update_config=1
network={
ssid="Illusionary 2"
mode=2
key_mgmt=WPA-PSK
psk="connectme"
frequency=2412
# My /etc/wpa_supplicant/wpa_supplicant-wlan1.conf:
country=GB
update_config=1
network={
ssid="ActualSSID"
psk="ActualPW"
# My wpa_supplicant@wlan1.service:
[Service]
ExecStartPre=/sbin/iptables -t nat -A POSTROUTING -o wlan1 -j MASQUERADE
ExecStopPost=-/sbin/iptables -t nat -D POSTROUTING -o wlan1 -j MASQUERADE
# My /etc/systemd/network/08-wlan0.network:
[Match]
Name=wlan0
[Network]
Address=192.168.4.1/16
IPForward=yes
DHCPServer=yes
[DHCPServer]
DNS=84.200.69.80 1.1.1.1
RouteMetric=200
# My /etc/systemd/network/12-wlan1.network:
[Match]
Name=wlan1
[Network]
Address=192.168.1.199/24
DNS=8.8.8.8 8.8.4.4
DHCP=yes
[Route]
Gateway=192.168.1.1
Metric=10
[DHPC]
RouteMetric=100
# ifconfig output:
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
inet 127.0.0.1  netmask 255.0.0.0
inet6 ::1  prefixlen 128  scopeid 0x10<host>
loop  txqueuelen 1000  (Local Loopback)
RX packets 12  bytes 600 (600.0 B)
TX packets 12  bytes 600 (600.0 B)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
inet 192.168.4.1  netmask 255.255.0.0  broadcast 192.168.255.255
inet6 fe80::dea6:32ff:fe03:2d7c  prefixlen 64  scopeid 0x20<link>
ether dc:a6:32:03:2d:7c  txqueuelen 1000  (Ethernet)
RX packets 0  bytes 0 (0.0 B)
TX packets 121  bytes 42965 (41.9 KiB)
wlan1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
inet 192.168.1.199  netmask 255.255.255.0  broadcast 192.168.1.255
inet6 fe80::76da:38ff:feea:7fcb  prefixlen 64  scopeid 0x20<link>
ether 74:da:38:ea:7f:cb  txqueuelen 1000  (Ethernet)
RX packets 6617  bytes 4308027 (4.1 MiB)
RX errors 0  dropped 1625  overruns 0  frame 0
TX packets 3264  bytes 481039 (469.7 KiB)
# iwconfig output:
wlan0     IEEE 802.11  Mode:Master  Tx-Power=31 dBm
Retry short limit:7   RTS thr:off   Fragment thr:off
Power Management:on
eth0      no wireless extensions.
lo        no wireless extensions.
wlan1     IEEE 802.11bgn  ESSID:"ActualSSID"  Nickname:"<WIFI@REALTEK>
Mode:Managed  Frequency:2.437 GHz  Access Point: 80:2A:A8:44:F6:19
Bit Rate:72.2 Mb/s   Sensitivity:0/0
Retry:off   RTS thr:off   Fragment thr:off
Power Management:off
Link Quality=99/100  Signal level=49/100  Noise level=0/100
Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
Tx excessive retries:0  Invalid misc:0   Missed beacon:0
# route -n output:
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.1.1     0.0.0.0         UG    10     0        0 wlan1
0.0.0.0         192.168.1.1     0.0.0.0         UG    1024   0        0 wlan1
192.168.0.0     0.0.0.0         255.255.0.0     U     0      0        0 wlan0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 wlan1
192.168.1.1     0.0.0.0         255.255.255.255 UH    1024   0        0 wlan1`
Updated 2019-10-25:
I've implemented Ingo's suggestions, but so far have had no luck with getting this to work. Access to the internet via wlan1 is (still) working locally, but wlan0 still doesn't connect clients to the internet.
My new /etc/systemd/network/08-wlan0.network:
[Match]
Name=wlan0
[Network]
Address=192.168.4.1/24
IPForward=yes
DHCPServer=yes
[DHCPServer]
My new /etc/systemd/network/12-wlan1.network:
[Match]
Name=wlan1
[Network]
DHCP=yes
My new ifconfig output:
        RX packets 156  bytes 15032 (14.6 KiB)
        TX packets 156  bytes 15032 (14.6 KiB)
        inet 192.168.4.1  netmask 255.255.255.0  broadcast 192.168.4.255
        RX packets 9  bytes 1107 (1.0 KiB)
        TX packets 139  bytes 42957 (41.9 KiB)
        inet 192.168.1.123  netmask 255.255.255.0  broadcast 192.168.1.255
        RX packets 2151  bytes 949342 (927.0 KiB)
        RX errors 0  dropped 129  overruns 0  frame 0
        TX packets 1043  bytes 244850 (239.1 KiB)
My new iwconfig output:
          Power Management:on
wlan1     IEEE 802.11bgn  ESSID:"ActualSSID"  Nickname:"<WIFI@REALTEK>"
          Encryption key:****-****-****-****-****-****-****-****   Security mode:open
          Link Quality=100/100  Signal level=53/100  Noise level=0/100
My new route -n output:
192.168.4.0     0.0.0.0         255.255.255.0   U     0      0        0 wlan0
Updated 2019-10-26, output from 2nd Pi:
iw wlan0 link:
Connected to dc:a6:32:03:2d:7c (on wlan0)
SSID: Illusionary 2
freq: 2412
RX: 21652487 bytes (154629 packets)
TX: 1115276 bytes (7331 packets)
signal: -20 dBm
tx bitrate: 72.2 MBit/s MCS 7 short GI
bbs flags: short preamble short-slot-time
dtim period: 2
beacon int: 100
ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:14:2d:b1 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.175/24 brd 192.168.2.255 scope global eth0:1
4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:0b:81:87:b9:bb brd ff:ff:ff:ff:ff:ff
inet 192.168.1.114/24 brd 192.168.1.255 scope global wlan0
inet6 fe80::20b:81ff:fe87:b9bb/64 scope link
You try to run Raspbian Stretch on a Raspberry Pi 4. On the release notes you will find:
2019-06-20:
* Based on Debian Buster
* Support for Raspberry Pi 4 hardware
This means Raspbian Stretch as predecessor from Rasbian Buster does not support Raspberry Pi 4. Before continue troubleshooting please start again with Raspbian Buster.
With your updated info I assume you have used a Raspbian Buster installation. I can see some problems with the configuration. You used in
[Match]
Name=wlan0
[Network]
IPForward=yes
DHCPServer=yes
[DHCPServer]
RouteMetric=200
The [DHCPServer] section does not define an option RouteMetric=. Look at man systemd.network. You must delete this line. But the main problem is that you use bitmask /16 with ip address 192.168.4.1/16. This selects the whole private subnet 192.168.0.0/16 with 65.536 ip addresses including the subnet for wlan1 (192.168.1.0/24 with 256 ip addresses). This superposition cannot work and may explain the problem you have find with ip addresses. Use ip address 192.168.4.1/24.
[Match]
Name=wlan1
[Network]
DNS=8.8.8.8 8.8.4.4
DHCP=yes
[Route]
Gateway=192.168.1.1
Metric=10
[DHPC]
RouteMetric=100
Here are some things wrong. You try to use a static ip address. Why? There is no need. Most problems we see here on this site is using a static ip address because it often conflicts with automatic DHCP network management. In addition you enabled getting an ip address by DHCP with DHCP=yes. This cannot work. I also don't understand why you use additional Sections [Route] and [DHPC]. The latter is a typo. Routing with Metric is managed automatically. Fiddling with manual settings will only confuse the routing table.
The routing table reflects the wrong configuration: two default routes to the same gateway with different Metric makes no sense, a big subnet on wlan0 and a part of it as smaller subnet on wlan1 will not work as intended.
Please just use exactly the configuration I have given in my tutorial. If it then run on your RasPi you can modify it to what you like.
Ingo
  • 42,961
  • 207
