I try to setup a raspberry zero as repeater. First i used that guide : https://kaiuwe.hüber.de/raspberry-pi-wifi-repeater-ohne-adapter/
But it's not a real repeater , but setting up a secondary wlan with another ssid. I need the same SSID that the zero is connected to , to be extended. So i came up with the proxy arp guide : Workaround for a wifi bridge on a Raspberry Pi with proxy arp
But i cant get it up and running.
Is it possible to setup a zero like that ?
                            v---proy arp---v
(Device) <---wireless---> (uap0)[Zero W](wlan0) <--wireless--> (Hotspot) -->inet
In general you have two ways to use two or more interfaces: routing or bridging. As you already have found, bridging on Raspberry Pi is limited. For some use cases you can emulate bridging with proxy arp. But you use a virtual interface uap0 that is derived from the only available physical interface wlan0. As far as I know there is no experience to use proxy arp on a virtual interface together with its own based physical interface. It may be possible but I suspect it will make trouble.
So I suggest to use routing. With it you can also get all services anywhere, on the RasPi, on your router, even on the whole world. How to setup a WiFi repeater using routing you can look at Access point as WiFi router/repeater, optional with bridge. Please don't confuse the optional bridge with the WiFi client uplink to your remote internet router. That bridge is used parallel to the access point of the RasPi and bridges two different interfaces.
Ingo
  • 42,961
  • 207
