I am using my RPi 3B purely for feeding data Flightradar24 (with Pi24 installed instead of pure Raspbian). I assume that usage of electronics and overall load of the device is rather low.
My temperature readouts with small fan installed are:
  • 39.7 to 40.8 degrees Celsius all the time, as reported by RPi via command line,
  • 34.3 to 34.9 degrees Celsius all the time, as measured by hardware thermometer with thermocouple attached to RPi's plastic case.
Since I saw temperature measured around 46 degrees Celsius on most of the screenshot, I assume above (low load of the device). Correct me, if I am wrong.
Given above and the fact that the fan is quite very noisy, can I consider running RPi 3B with Pi24 completely without any cooling methods, i.e. without a fan and without a radiator? Or is it too risky?
trejder
  • 141
My RPis has been running for two years without heatsinks in India.These are working fine at 40 to 50 degrees also.
Nagaraj
  • 119
My flightradar 3B sits on the window sill because the aerial cable goes though the hinged side of that window.
That one is running 24/365 with a current temp of 47.8° compared with an ambient temp of 19.7°
No case, fan or heatsink on that one.
Dougie
  • 5,381
  • 22
  • 30
My Pi3 has been running for years without a heatsink in Sydney where the Summer temperature regularly exceeds 40 degrees
