I am looking for optical Toslink input for Raspberry pi (any model). If I just connect a DLR-1140 receiver to PCM_DIN, would that work?
My goal is to build a sound server. I have a TV that outputs Toslink signal, a sound system that needs analog 6ch input, bluetooth clients and network pulseaudio clients. The main missing piece is the Toslink input.
I already tried a CM106-based USB card, but found out that it does not allow encoded signal into the system (only passthrough is allowed). It cannot decode it either.
It's not as simple as directly connect a S/PDIF or Toslink connector to the Pi. From Can I get audio input through the GPIO, the pins that include PCM_DIN directly take PCM streams, like a WAV file. To get data from a Toslink, you'd need some chip to convert from the IEC 60958 protocol to raw PCM. Something like a LC89091JA "Digital Audio Interface Receiver" might work. (Side note: this sounds like an interesting project for an FPGA.)
Additional reading:
Fred
  • 4,592
  • 29
