43
I've never used linux before, so this may be a problem with that, but I'm trying to simply SSH into my friends webserver using the info he gave me. I looked up that the linux command to ssh is ssh username@hostname. I'm not trying to type that into LXTerminal but everytime I hold shift and hit the number two I don't get @ I get ". Any ideas?
EGHDK
  • 1,351
You need to remap your keyboard. By default it is set to a UK map.
at the command line type:
sudo nano /etc/default/keyboard
and hit enter. locate the following line
XKBLAYOUT=”gb”
Change the gb to us (This assumes you want a us mapping, if not replace the gb with the two letter code for your country)
and reboot your machine.
if it pauses for a long time during the keyboard mapping stage, enter the following at the command line:
sudo setupcon
Your next reboot should be much faster.
Reference:
http://elinux.org/index.php?title=R-Pi_Troubleshooting&oldid=147362#Re-mapping_the_keyboard_with_Debian_Squeeze
Steve Robillard
  • 34,988
  • 106
  • 110
23
Steve's answer, though correct at the time, is now somewhat out of date. In Raspbian:
sudo raspi-config
and go to the configure_keyboard section with 4 Internationalisation Options -> I3 Change Keyboard Layout
You can choose the correct keyboard type and layout from there.
Ross Rogers
  • 609
scruss
  • 9,117
  • 25
  • 36
Raspberry Pi configuration has changed as of Jessie (2017):
  1. raspi-config no longer offers Internationalisation Options. The Localisation Options has no submenu for Change Keyboard Layout
  2. Simply setting XKBLAYOUT="us" may default to the Spanish layout.
This worked for me:
And these were my settings (I'm Canadian):
XKBMODEL="pc104"
XKBLAYOUT="ca"
XKBVARIANT="eng"
For our southern neighbors:
XKBMODEL="pc104"
XKBLAYOUT="us"
XKBVARIANT=""
There is, however, a bug with that. When you check in
Pi > Preferences > Raspberry Pi Configuration
Pi > Preferences > Keyboard and Mouse.
it will show United States > Spanish (Latin American). I don't think it affects functionality.
To find out the layout you want, run this in the Terminal:
rc_gui
Then click on Localisation > Set Keyboard... and make your change. Click OK to close the Keyboard Layout dialog. Click Set Keyboard... once more. This time, the terminal window you will show:
Sections: ['Global']
Layouts: ['ca']
Variants: ['eng']
Options: []
Now you can put those into your
Layouts --> XKBLAYOUT
Variants --> XKBVARIANT
Colin
  • 281
Another option that doesn't use the Terminal is going into (from the GUI), Menu > Preferences > Raspberry Pi Configuration > Localization > Set Keyboard, and set it according to where you live.
