13
I'm attempting to set up my Raspberry Pi with Wheezy Raspbian 2013-02-09 as an NFS server (client will be Ubuntu 12.10). I have followed these instructions.
I can't start the service and get the following message:
$ sudo service nfs-kernel-server restart
[ ok ] Stopping NFS kernel daemon: mountd nfsd.
[ ok ] Unexporting directories for NFS kernel daemon....
[ ok ]   Exporting directories for NFS kernel daemon....
[....] Starting NFS kernel daemon: nfsd
[warn] Not starting: portmapper is not running ... (warning).
$ rpcinfo -p
<br>rpcinfo: can't contact portmapper: RPC: Remote system error - No such file or directory
Not sure what is missing?
d2le
  • 133
9 Answers9
10
I had to restart rpcbind service to work:
$ sudo service rpcbind restart
I've found it out in this thread
RPiAwesomeness
  • 3,021
  • 52
Bubu
  • 101
A moderator in this forum post said that this command would work:
sudo update-rc.d rpcbind enable && sudo update-rc.d nfs-common enable
benathon
  • 391
syb0rg
  • 8,178
  • 38
...does work, but the "portmapper is not running" problem will reappear on the next reboot.
The bottom of this page has a fix that will survive a reboot, but be aware it will delete your /etc/exports. In short, backup your /etc/exports then:
sudo apt-get purge rpcbind
sudo apt-get install nfs-kernel-server
Then restore your /etc/exports.
I am running Raspbian Jessie Lite (released on Mar 18, 2016), and got the same issue. Here is my steps to completely fix this issue, even if after a reboot.
Firstly have a look at the init file for /etc/init.d/nfs-kernel-server, you should notice its start runlevel is 2,3,4,5.
Also look at the following files' start runlevel, which is S only. I changed its runlevel to 2,3,4,5.
/etc/init.d/nfs-common
/etc/init.d/rpcbind
Then try to update-rc.d the changed init scripts with defaults. First try fails. The trick is to remove and add them again.
update-rc.d -f rpcbind remove
update-rc.d rpcbind defaults
update-rc.d -f nfs-common remove
update-rc.d nfs-common defaults
update-rc.d -f nfs-kernel-server remove
update-rc.d nfs-kernel-server defaults
After that, check the order of the services. It should be rpcbind, nfs-common, and nfs-kernel-server.
I also posted a blog for this. You can also find it here.
lesca
  • 173
The underlying problem is the symlinks in /etc/rc*.d are scattered around a bit. Some of the suggestions above rely on remaking these links and, perhaps, they get made with more appropriate order. Sometimes. Try -
for i in rpcbind nfs-common nfs-kernel-server ; do find /etc/rc* -name "S*$i*"; done
to see when they are started. In reality, you only need them started at level 3, so I edited /etc/init.d/rcpbind, /etc/init.d/nfs-common and /etc/init.d/nfs-kernel-server so "# Default-Start: 3" and ran this to enforce it -
for i in rpcbind nfs-common nfs-kernel-server ; do update-rc.d -f "$i" remove; update-rc.d "$i" defaults; done
Note that update-rc.d will not change an existing entry and silently fails to remove an entry (if script still exists) unless you add the -f. Ideally you will end up with something like this -
/etc/rc3.d/S01rpcbind
/etc/rc3.d/S02nfs-common
/etc/rc3.d/S03nfs-kernel-server
And it will now boot cleanly. An update to NFS may well overwrite your good work...
I was struggling with the same issue as well. The above solutions didn't work. In my case it came from an issue with my locales. The following line popped up in the terminal during installation of: nfs-kernel-server nfs-common rpcbind.
perl: warning: Setting locale failed.
Make sure you don't see an error about your locales during the installation of these packages. I fixed my locales, reinstalled the packages and now it works.
Rotareti
  • 189
This works for me. Clean and resists reboots.
You have to setup systemd to do the order properly
cat <<EOF | sudo tee -a /etc/systemd/system/nfs-common.services
[Unit]
Description=NFS Common daemons
Wants=remote-fs-pre.target
DefaultDependencies=no
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStart=/etc/init.d/nfs-common start
ExecStop=/etc/init.d/nfs-common stop
[Install]
WantedBy=sysinit.target
EOF
cat <<EOF | sudo tee -a /etc/systemd/system/rpcbind.service
[Unit]
Description=RPC bind portmap service
After=systemd-tmpfiles-setup.service
Before=remote-fs-pre.target
[Service]
ExecStart=/sbin/rpcbind -f -w
KillMode=process
Restart=on-failure
[Install]
Alias=portmap
EOF
sudo systemctl enable nfs-common
sudo systemctl enable rpcbind
sudo reboot
taken from here
https://github.com/geerlingguy/raspberry-pi-dramble/issues/65#issuecomment-283046966
nachoparker
  • 141
I fixed it with: $ sudo service portmap start Then restart nfs service: $ sudo service nfs-kernel-server restart
and it works.
I have tested most of the previous solutions, they don't work after a restart of the Raspberry Pi ( the command rpcinfo -p | grep nfs gave me nothing ).
Solution :
echo service nfs-kernel-server restart | sudo tee -a /etc/rc.local
or
sudo vi /etc/rc.local
To verify :
> sudo shutdown -r now
Tested on Raspian 8 (jessie)
Stéphane B.
  • 123
