I am trying to connect to a mobile network using the ZTE MF190 USB dongle on my Raspberry Pi. I already successfully established the UMTS connection directly on the Pi's USB host, but later I added a powered USB hub and moved the UMTS dongle on to it. (I also make some modifications to my system later on). Now, the lsusb gives me this:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 057: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 061: ID 19d2:0117 ZTE WCDMA Technologies MSM
Suddenly I can not make any connection using Sakis3g. dmesg gives me this:
[1396425.801185] usb 1-1.2.1: new high-speed USB device number 60 using dwc_otg
[1396425.903307] usb 1-1.2.1: New USB device found, idVendor=19d2, idProduct=2000
[1396425.903336] usb 1-1.2.1: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[1396425.903354] usb 1-1.2.1: Product: ZTE WCDMA Technologies MSM
[1396425.903383] usb 1-1.2.1: Manufacturer: ZTE,Incorporated
[1396425.903400] usb 1-1.2.1: SerialNumber: MF190***omitted***
[1396425.919933] scsi14 : usb-storage 1-1.2.1:1.0
[1396428.124256] usb 1-1.2.1: USB disconnect, device number 60
[1396428.361269] usb 1-1.2.1: new high-speed USB device number 61 using dwc_otg
[1396428.463526] usb 1-1.2.1: New USB device found, idVendor=19d2, idProduct=0117
[1396428.463555] usb 1-1.2.1: New USB device strings: Mfr=3, Product=2, SerialNumber=4
[1396428.463572] usb 1-1.2.1: Product: ZTE WCDMA Technologies MSM
[1396428.463588] usb 1-1.2.1: Manufacturer: ZTE,Incorporated
[1396428.463618] usb 1-1.2.1: SerialNumber: MF190***omitted***
[1396428.467838] option 1-1.2.1:1.0: GSM modem (1-port) converter detected
[1396428.468389] usb 1-1.2.1: GSM modem (1-port) converter now attached to ttyUSB0
[1396428.469150] option 1-1.2.1:1.1: GSM modem (1-port) converter detected
[1396428.469723] usb 1-1.2.1: GSM modem (1-port) converter now attached to ttyUSB1
[1396428.470497] option 1-1.2.1:1.2: GSM modem (1-port) converter detected
[1396428.475264] usb 1-1.2.1: GSM modem (1-port) converter now attached to ttyUSB2
My /etc/sakis3g.conf looks like this:
APN=internet
APN_USER=<my_username>
APN_PASS=<my_pass>
USBDRIVER="option"
MODEM="OTHER"
OTHER="USBMODEM"
# This is my usbswitch mode for ZTE MF190:
USBMODEM="19d2:0117"
But when I run sudo sakis3g connect -debug, I get this on the end of the debug file:
some debugging info, everything seems OK till here I guess:
AT communication is OK, PDP context is getting established:
AT+CGDCONT=1,"IP","internet"
OK
[10171] [22:28:42] Will now run command: \'/bin/rm -f "/tmp/sakis3g.3gnet"\'
[10171] [22:28:42] Command returned 0.
[10171] [22:28:42] We are root already. Proceeding.
[10171] [22:28:42] Device /dev/ttyUSB2 is not busy.
[10171] [22:28:42] Verbosing: 42% Connecting
[10171] [22:28:43] PID 12827 is still running.
[10171] [22:28:43] Located "netstat" within PATH (/bin/netstat).
[10171] [22:28:43] Waiting for interface to go up (0 seconds passed).
[10171] [22:28:44] PID 12827 is still running.
[10171] [22:28:44] Interface ppp0 is up.
[10171] [22:28:44] Waiting for interface to go up (1 seconds passed).
[10171] [22:28:45] PID 12827 is still running.
[10171] [22:28:45] Interface ppp0 is up.
[10171] [22:28:45] Waiting for interface to go up (2 seconds passed).
[10171] [22:28:46] PID 12827 is still running.
[10171] [22:28:47] Interface ppp0 is up.
..till the script ends (after second connection attempt) resulting in no GPRS/UMTS/HSDPA connectivity.
I do not understand, why does my script on the one hand saying Interface ppp0 is up., but on the other Waiting for interface to go up (XX seconds passed).?
My system is made of:
pi@pinew ~ $ uname -a
Linux pinew 3.6.11+ #456 PREEMPT Mon May 20 17:42:15 BST 2013 armv6l GNU/Linux
pi@pinew ~/sakis3g $ ./sakis3g --version
Sakis 3G All-in-one script - Version 0.2.0e
(c) Sakis Dimopoulos 2009, 2010 under GNU GPL v2
pi@pinew ~ $ wvdial --version
WvDial 1.61
Copyright (c) 1997-2005 Net Integration Technologies, Inc.
I also tried:
1) With some other USB modem (Huawei E220), but the problem persists (YES, I have changed the sakis3g.conf file).
2) On another Raspberry Pi, (with the same Raspbian version installed), but the problem persists.
3) Another SIM card, (I replace the current data SIM with my personal phone's SIM), but the problem persists.
4) Changing the powered USB hub, (replacing Genesys Logic with LogiLink 4x USB 2.0 powered hub), but the problem persists.
Is there anything else I have forgotten and is worth trying to establish with the UMTS connection and the USB dongle?
