I haven't run apt upgrade on my Pi 3 in a while and did it today. It resulted in an error message with my /boot partition being filled to 100%. Any subsequent apt commands are resulting in errors because the /boot partition is full (apt-get autoremove is a common suggestion, but that won't work).
I've seen on other sites suggestions to check what kernels are installed using a variant of sudo dpkg --list 'linux-image*', but when I run this I get no results (it appears no kernels are installed anymore).
Here is the output from ls -la for my /boot partition:
pi@raspberry ~ % ls -la /boot
total 41056
drwxr-xr-x 4 root root 2560 Sep 15 23:10 .
drwxr-xr-x 25 root root 4096 Jun 10 2017 ..
-rwxr-xr-x 1 root root 15660 Sep 15 23:05 bcm2708-rpi-0-w.dtb
-rwxr-xr-x 1 root root 15197 Sep 15 23:05 bcm2708-rpi-b.dtb
-rwxr-xr-x 1 root root 15456 Sep 15 23:05 bcm2708-rpi-b-plus.dtb
-rwxr-xr-x 1 root root 14916 Sep 15 23:05 bcm2708-rpi-cm.dtb
-rwxr-xr-x 1 root root 16523 Sep 15 23:05 bcm2709-rpi-2-b.dtb
-rwxr-xr-x 1 root root 17624 Sep 15 23:05 bcm2710-rpi-3-b.dtb
-rwxr-xr-x 1 root root 16380 Sep 15 23:05 bcm2710-rpi-cm3.dtb
-rwxr-xr-x 1 root root 50248 Sep 15 23:05 bootcode.bin
-rwxr-xr-x 1 root root 187 Dec 31 1979 cmdline.txt
-rwxr-xr-x 1 root root 1662 May 31 2017 config.txt
-rwxr-xr-x 1 root root 18693 Sep 15 23:05 COPYING.linux
-rwxr-xr-x 1 root root 41 May 31 2017 .firmware_revision
-rwxr-xr-x 1 root root 2583 Sep 15 23:04 fixup_cd.dat
-rwxr-xr-x 1 root root 6674 Sep 15 23:04 fixup.dat
-rwxr-xr-x 1 root root 9813 Sep 15 23:05 fixup_db.dat
-rwxr-xr-x 1 root root 9813 Sep 15 23:05 fixup_x.dat
-rwxr-xr-x 1 root root 10201980 May 31 2017 initrd.img-4.9.30-v7+
-rwxr-xr-x 1 root root 10174464 Sep 15 23:10 initrd.img-4.9.30-v7+.dpkg-bak
-rwxr-xr-x 1 root root 145 Apr 10 2017 issue.txt
-rwxr-xr-x 1 root root 4579248 Sep 15 23:05 kernel7.img
-rwxr-xr-x 1 root root 4379032 Sep 15 23:05 kernel.img
-rwxr-xr-x 1 root root 1494 Sep 15 23:05 LICENCE.broadcom
-rwxr-xr-x 1 root root 18974 Apr 10 2017 LICENSE.oracle
drwxr-xr-x 2 root root 10240 Sep 15 23:05 overlays
-rwxr-xr-x 1 root root 659492 Sep 15 23:04 start_cd.elf
-rwxr-xr-x 1 root root 4993604 Sep 15 23:04 start_db.elf
-rwxr-xr-x 1 root root 2855556 Sep 15 23:04 start.elf
-rwxr-xr-x 1 root root 3939492 Sep 15 23:04 start_x.elf
drwxr-xr-x 2 root root 512 May 30 2017 System Volume Information
output of df -h
pi@raspberry ~ % df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 30G 4.0G 24G 15% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 6.6M 456M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 462M 0 462M 0% /sys/fs/cgroup
/dev/mmcblk0p1 41M 41M 3.5K 100% /boot
/dev/sda1 116G 854M 114G 1% /usr/local/src
/dev/sda1 116G 854M 114G 1% /home
tmpfs 93M 4.0K 93M 1% /run/user/1000
Output of sudo apt-get autoremove:
pi@raspberry ~ % sudo apt-get autoremove
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 8 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up initramfs-tools (0.120+deb8u3) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.120+deb8u3) ...
ln: failed to create hard link ‘/boot/initrd.img-4.9.30-v7+.dpkg-bak’ => ‘/boot/initrd.img-4.9.30-v7+’: Operation not permitted
cp: error writing ‘/boot/initrd.img-4.9.30-v7+.dpkg-bak’: No space left on device
cp: failed to extend ‘/boot/initrd.img-4.9.30-v7+.dpkg-bak’: No space left on device
dpkg: error processing package initramfs-tools (--configure):
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Output of dpkg --list 'linux-image*':
pi@raspberry ~ % dpkg --list 'linux-image*'
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linux-image <none> <none> (no description available)
What do I need to do to get this fixed and have apt upgrade succeed?
