I am using Raspberry PI Model B with Raspbian, installed by NOOBS, upgraded to the latest version. The NTP server is automatically started in the boot process.
When I boot my RPI, the time is always wrong — about 15 minutes in the past. Even if I wait for several hours, it's incorrect.
I run
/etc/init.d/ntp restart
manually and it sets the correct time within seconds, sometimes it needs two restarts.
I define several servers in the ntp.conf:
 server ntp1.t-online.de iburst prefer
 server 0.de.pool.ntp.org iburst
 server 1.de.pool.ntp.org iburst
 server 2.de.pool.ntp.org iburst
 server 3.de.pool.ntp.org iburst
Does anyone have an idea how to fix this?
Steve Robillard
  • 34,988
  • 106
  • 110
Railsana
  • 151
Are you using DHCP or static IP?
If you use DHCP then it will read /var/lib/ntp/ntp.conf.dhcp, not /etc/ntp.conf
If you use a static IP, remove /var/lib/ntp/ntp.conf.dhcp if it exist.
Either way, check if ntp is running after a reboot with ps aux | grep ntp If it is, then run ntpq -p to check if it has started to sync with the timeservers. This can take some time, sometime it needs 2-3 pulls, each taking about 60 seconds. Just rerun ntpq -p to see the status.
Sitron_NO
  • 186
I don't know what exactly went wrong, but something messed up the whole setup. I reinstalled Raspbian (via NOOBS) and all NTP settings worked fine again.
Railsana
  • 151
Here is a script that you can set to run on boot to fix your time
#!/bin/bash
#Visit www.timeapi.org to find the correct url for your timezone. Then
replace the url in the first line
time=$(wget http://www.timeapi.org/utc/in+two+hours?format=%25d%20%25b%20%25Y%20%25I:%25M:%25S -q -O -)
echo "Time set to:"
sudo date -s "\`echo $time`"
RPiAwesomeness
  • 3,021
  • 52
