The time on my Raspberry Pi is off by a few days. When I try
$ sudo dpkg-reconfigure ntp
it doesn't change the time, but some stuff comes up in the syslog:
Oct 21 18:27:45 airpiClock ntpd[2142]: ntpd exiting on signal 15
Oct 21 18:27:51 airpiClock ntpd[2758]: ntpd 4.2.6p5@1.2349-o Fri May 18 20:30:57 UTC 2012 (1)
Oct 21 18:27:51 airpiClock ntpd[2759]: proto: precision = 1.000 usec
Oct 21 18:27:51 airpiClock ntpd[2759]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Oct 21 18:27:51 airpiClock ntpd[2759]: Listen normally on 1 lo 127.0.0.1 UDP 123
Oct 21 18:27:51 airpiClock ntpd[2759]: Listen normally on 2 wlan0 192.168.2.141 UDP 123
Oct 21 18:27:51 airpiClock ntpd[2759]: peers refreshed
Oct 21 18:27:51 airpiClock ntpd[2759]: Listening on routing socket on fd #19 for interface updates
Oct 21 18:27:51 airpiClock ntpd[2759]: restrict: error in address '::' on line 38. Ignoring...
I found that when I reverted from a static IP address to DHCP and rebooted, the date and time were corrected. I need to keep a static IP address, but I also need to be able to accurately schedule tasks, so the date and time must be correct.
This is what my /etc/network/interfaces file looks like:
auto lo
iface lo inet loopback iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet static
address 192.168.2.143 netmask 255.255.255.0 network 192.168.2.0 broadcast 192.168.2.255 gateway 192.168.2.1
wpa-ssid "ssid" wpa-psk "password"
What do I need to change in order to be able to have a static IP address and accurate time?
MichaelBaker
  • 123
Though Lenik's suggestion of using ntpdate helped me initially, I've since read that ntpdate is deprecated, so I kept trying to get ntpd to do what it's supposed to.
On another forum, somebody mentioned a version of Raspbian that was missing something from the NTP library, and that a reinstall fixed it:
sudo apt-get --reinstall install ntp
This ended up working for me. I am still not sure how it was related to the static IP address.
Peter Mortensen
  • 2,004
MichaelBaker
  • 123
has nothing to do with getting the time from the Internet. The correct way would be:
$ sudo ntpdate pool.ntp.org
or you may specify any of your favourite servers. regarding the static address, most probably your router has no idea about this address and effectively disable outbound internet access for your RasPi. you should setup your DHCP server to allocate the IP address based on the MAC, and then specify RasPi MAC address to be given specific IP address all the time. usually this kind of settings are available in your router (or whatever device you use as DHCP server).
lenik
  • 11,533
  • 37
On the Raspbian, there is generated a file /var/lib/ntp/ntp.conf.dhcp by the dhcp-client, and that is generated on the basis of your DHCP-server and what it tells the client.
If you do not use DHCP, delete it. Then ntp will read /etc/ntp.conf If you do not have one, use this:
# /etc/ntp.conf, configuration for ntpd
logfile /var/log/ntpd
driftfile /var/lib/ntp/ntp.drift
# NTP servers
server <your local NTP server> # Delete line if you do not have one
server 0.pool.ntp.org
server 1.pool.ntp.org
server 2.pool.ntp.org
server 3.pool.ntp.org
# Default restriction. See
# http://support.ntp.org/bin/view/Support/AccessRestrictions
restrict default kod nomodify notrap nopeer noquery
restrict -6 default kod nomodify notrap nopeer noquery
# Allow localhost (via the "ntpq" command)
restrict 127.0.0.1
restrict -6 ::1
Restart the ntp, then use ntpq -p to see if your getting info from your peers/servers.
And one final note: If your clock is more that 1000s inaccurate, ntp will quit. You have to adjust the time manually via date
Sitron_NO
  • 186
All these pools are going to be way down the list of handoffs between systems all the way back to Stratum-1.
What you need to do is modify your ntpd to reach the official Master Clock at time.nist.gov.
Here is a Q&A on this Stack Exchange that explains the process.
How do I set Raspbian to use the primary time server time.nist.gov?
It makes a huge difference when you are trying to synchronize multiple Raspian or ubuntu or Windows systems so they all have the correct time down to the microsecond.
SDsolar
  • 2,378
  • 26
  • 43
