Goal
Hi my PI keeps rebooting after I added two lines to the rc.local file. Now i am trying to log into the boot shell and edit those two lines out.
Problem
I added init=/bin/bash to the cmdline.txt and it looks like the following:
 dwc_otg.lpm_enable=0 root=PARTUUID=61f5b861-02 rootfstype=ext4 elevator=deadline
fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles init=/bin/bash
I then can successfully log into the boot shell and type at the command line. However, whenever I've tried the following commands to remount the file system as read/write:
mount -n -o remount,rw /
it gave an error: mount: can't find PARTUUID=61f5b861-02
Then after I read some posts on the forum, I changed the root in my cmdline.txt to the following:
 dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline
And then i ran the command: mount: mount point /dev/mmcblk0p2 / It just worked...
Can somebody explain what happened? This doesn't seem to be the solution for anybody else.
Reference:
https://www.raspberrypi.org/forums/viewtopic.php?p=1284212
How do I start up in safemode?
Yihan Hu
The root= field from cmdline.txt specifies to the kernel where the partition with the root filesystem is. There are a few ways that can be specified. The one that is generally preferred in the linux world is UUID or PARTUUID, because it depends on a fixed identifier assigned to the partition as opposed to the other commonplace method, a /dev node, which is less predictable on systems that have various sorts of storage attached the configuration of which may change, meaning the associated /dev node would then change, whereas the UUID would not.
There's a bit of a complication with PARTUUID, though, which is really intended for use on GPT disks, but is also something that Windows systems won't get wrong when dealing with ext4 partitions, for a further explanation:
https://raspberrypi.stackexchange.com/a/95436/5538
Anyway, when you copy a partition, unlike the UUID, the PARTUUID doesn't go with it, which is why they can get lost. Conversely, if you copy cmdline.txt around, you'll end up with a mismatch.
However, in the context of a normal 2 partition Rpi SD card, /dev/mmcblk0p2 is unequivocal: It means the second partition on the first SD block device.
You can check the PARTUUID on a running system with:
blkid /dev/mmcblk0p2
Chances are it isn't 61f5b861-02.
