16
I am using the Pi as display only device,to show a video feed, so I have no icons and no wallpaper. But the mouse cursor is right there in the middle and when I start the video it gets bigger because of the video resolution. So I wanted to disable it completely.
Any help?
(off-topic) Setting the wallpaper to a blank screen or reducing that inactivity time where the screens blanks wold be useful too.
techraf
  • 4,353
  • 43
rcsimoes
  • 171
The following:
sudo apt-get install unclutter
unclutter -display :0 -noevents -grab
is known to work perfectly on Raspbian Wheezy.
techraf
  • 4,353
  • 43
lenik
  • 11,533
  • 37
10
The X server has an option -nocursor which would permanently turn off the mouse cursor.
You'd need to edit /etc/X11/xinit/xserverrc to add the option to the default X startup.
I looked around for other places to possibly inject the additional option (-nocursor), but nothing else comes to mind that is display manager agnostic (LXDE, KDE, GNOME, AwesomewM, Fluxbox, etc).
Unclutter (mentioned by @lenik) is also a good solution, although it's often not invoked until a user logs in, which may or may not happen in your case, depending on how you're using the system.
lornix
  • 1,066
Edit the file /etc/lightdm/lightdm.conf by, for example using nano:
# nano /etc/lightdm/lightdm.conf
First find the line xserver-command=X, you can do this in nano using:
ctrl+w xserver-command=X
uncomment the line and add:
-nocursor
So it looks like this:
xserver-command=X -nocursor
Darth Vader
  • 4,218
  • 47
  • 70
700L
On the latest Raspbian Stitch (4.9.59-v7+), using unclutter seem the best way with simple options of relevant control. One thing I noticed is that using -idle 0 is a bad idea, and make the mouse flicker and overload the CPU. However, any number above 1s is good. The best option I found seem to be:
unclutter -display :0 -idle 3 -root -noevents
If you want this to start automatically, you have two add this line prefixed with an @ in one of two choices of where to put it:
  1. /etc/xdg/lxsession/LXDE-pi/autostart (recommended)
  2. /etc/xdg/lxsession/LXDE/autostart
Not sure what's the difference, but the LXDE-pi one is working.
not2qubit
  • 1,439
