9
I have been using a RPi3 for the last year without any issues. I have had rpi-update as part of a regular update process (cron job). Lately I have been experiencing crashes. I started to investigate, and while there is nothing helpful in the syslog I saw a new warning message that rpi-update updates to pre-releases of the linux kernel tree and Videocore firmware. That might be causing my crashing problems.
So how do I roll back to the latest stable Videocore firmware and kernel without reinstalling Raspbian?
user643011
  • 200
"In normal circumstances there is NEVER a need to run rpi-update as it always gets you to the leading edge firmware and kernel and because that may be a testing version it could leave your RPi unbootable". https://www.raspberrypi.org/forums/viewtopic.php?p=916911#p916911 Even the rpi-update documentation now warns "Even on Raspbian you should only use this with a good reason. This gets you the latest bleeding edge kernel/firmware."
sudo apt-get update; sudo apt-get install --reinstall raspberrypi-bootloader raspberrypi-kernel will put it back to the latest supported kernel/bootcode.
Update for later OS (pre Bookworm):-
sudo apt install --reinstall libraspberrypi0 libraspberrypi-{bin,dev,doc} raspberrypi-{kernel,bootloader}
