I am having difficulties getting my scanner to operate. I am using Raspbian Buster on a raspberry pi 3b+. My scanner is a USB Canon LIDE 110, which is connected to the pi through a powered USB hub.
The issue I am having is that I can't seem to use the scanner without root. If I try
scanimage -L
it doesn't detect it, but
sudo scanimage -L
returns
device `genesys:libusb:001:008' is a Canon LiDE 110 flatbed scanner
Likewise if I run xsane, it doesn't detect the scanner, but running it with sudo brings up the GUI and everything proceeds as normal. However the images I save are only accessible to root.
I have added myself to the scanner group, which doesn't seem to have changed anything, and I'm out of ideas.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
Shaker
  • 41
Check your scanner's "idVendor" and "idProduct" values with a lsusb command. Add a udev rule
ATTRS{idVendor}=="04a9", ATTRS{idProduct}=="1908", MODE="0664", GROUP="scanner", ENV{libsane_matched}="yes"
Reload udev with sudo udevadm control --reload-rules.
Add your userid (I'm assuming you're logging in as pi) to the scanner group sudo groupadd scanner and sudo usermod -a -G scanner pi and you should be able to access the scanner without needing sudo.
Plug your scanner in and it should work. Note: I've not tested this.
Dougie
  • 5,381
  • 22
  • 30
