I'm trying to execute this piece of code to run 2 motors on my robot. The code is really simple it's just repetitive.
For some reason that I can't figure out, the motors run unevenly. Here is the code for the testing file:
import RPi.GPIO as GPIO
import motor2
print("directions: ")
print("f = go forward\n")
print("b = go backward\n")
print("l = go left\n")
print("r = go right\n")
print("s = stop\n")
print("q = to exit program\n")
try:
    while True:
                direction = input("Please enter the  direction you want to go, e.g: f ")
                print('You entered', direction)
                if direction == 'q':
                    quit()
                t = int(input("Please enter the power the wheels\n"))
                if direction == 'f':
                    motor2.forward(t)
                elif direction == 'b':
                    motor2.backward(t)
                elif direction == 'r':
                    motor2.turnright(t)
                elif direction == 'l':
                    motor2.turnleft(t)
                elif direction == 's':
                    motor2.stopMotor(t)
except KeyboardInterrupt:
    print('key board interrupted!')
finally:
    GPIO.cleanup()
This is motor2.py: the file that it refers to:
def init():
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(13,GPIO.OUT)
    GPIO.setup(3,GPIO.OUT)
    GPIO.setup(16,GPIO.OUT)
    GPIO.setup(20,GPIO.OUT)
    GPIO.setup(27,GPIO.OUT)
    GPIO.setup(21,GPIO.OUT)
def forward(tf):
    init()
    p1 = GPIO.PWM(20,50)
    p2 = GPIO.PWM(16,50)
    p1.start(30)
    p2.start(30)
    GPIO.output(20, True)
    GPIO.output(27, True)
    GPIO.output(21, False)
    GPIO.output(13, False)
    GPIO.output(3, True)
    GPIO.output(16, True)
    time.sleep(tf)
    GPIO.cleanup()
def backward(tf):
    init()
    p1.start(30)
    p2.start(30)
    GPIO.output(20, False)
    GPIO.output(21, True)
    GPIO.output(13, True)
    GPIO.output(16, False)
    time.sleep(tf)
    GPIO.cleanup()
def turnright (tf):
    init()
    p1 = GPIO.PWM(21,50)
    p1.start(50)
    p2.start(50)
    time.sleep(tf)
    GPIO.cleanup()
def turnleft(tf):
    init()
    p1.start(50)
    p2.start(50)
    time.sleep(tf)
    GPIO.cleanup()
def stopMotor(tf):
    init()
    time.sleep(tf)
The pin numbers have been entered correctly and the wiring has been checked. Any and everytime I run this the right motor gets more power than the left. Any help would be greatly appreciated!
Shreesh
There are all sorts of reasons why one side might turn faster than the other. Unless there is an obvious problem turning the wheel by hand there is probably nothing wrong with the motor.
The normal approach would be to vary the amount of power you send to each motor by changing the PWM dutycycle. Provide a higher dutycycle for the slower motor.
joan
  • 71,852
  • 76
  • 108
