-2
I'm trying to fix this code for a robot with multiple sensors. The values of TRIG and ECHO are input through another part of the code.
Set this at the beginning of the code
def init():
    GPIO.setmode(GPIO.BOARD)
This is the function where I'm getting the error
def getSensor(TRIG,ECHO):
    try:
        init()
        #Set the pins for TRIG, trig is the output pin
        GPIO.setup(TRIG,GPIO.OUT) #Error right here
        #Set the pins for ECHO, echo is the input pin
        GPIO.setup(ECHO,GPIO.IN)
        #3.3v sent to trig
        GPIO.output(TRIG,1)
        #turn off the trig pin
        GPIO.output(TRIG,0)
        while GPIO.input(ECHO) == 0:
            pass
        start = time.time()
        while GPIO.input(ECHO) == 1:
            pass
        stop = time.time()
        reading = (stop - start) * 17000
        return reading
    except KeyboardInterrupt:
        print ("Interrupted by keyboard")
    except:
        print ("Other error or exception occured")
    finally:
        GPIO.cleanup()
How can I fix this? I can't figure out where I'm going wrong
Shreesh
Debugging without all relevant code is a hit and miss affair.
Your problem is most likely to be caused by calling GPIO.setup() inside a function. This should be called ONCE in your program.
Calling GPIO.setmode multiple times is also an error it definitely should be called ONCE only.
NOTE there is actually nothing wrong with calling the setup multiple times, but Python is quite correctly warning you.
I'm guessing you don't see this every time, but maybe every 2nd run? Here's why: When you run it the first time, your code exits the function through the 'return reading' statement, skipping the gpio.cleanup() line. This leaves the pins in an 'in use' state.
When is gets called again or you run it a second time, your call to gpio.setup() triggers an exception, but then in your finally clause you call gpio.cleanup() which frees up the pins. If you run it again, it'll work starting the cycle over.
The solution is to simply add a gpio.cleanup() before the return statement
tbitson
  • 161
