I have connected my desktop computer (running Ubuntu 16.04) to my Raspberry Pi through a router (ethernet connection). My computer can access internet with USB tethering from my phone. I can SSH to the Raspberry Pi, but it cannot connect to internet.
ping google.com says ping: google.com: Temporary failure in name resolution
sudo apt update says Temporary failure resolving 'raspbian.raspberrypi.org'.
How to forward my computer's internet connection to Raspberry Pi?
The router is only connected to the desktop and the Raspberry Pi.
Update:
I directly connected the Raspberry Pi to my computer through ethernet, and connected a monitor to the Pi. Then I ran ifconfig in the Pi to get its IP address (it was 10.42.0.38, maybe this is the default?)
Then I sshed to the RPi from my desktop, and now it is connected to the internet. However, this does not solve the issue when RPi is connected to a router and there is no way to connect a display.
If you can ping an IP address (like 8.8.8.8) but not a URL, you have a problem with accessing a DNS server to look up names.
It's really hard to understand how your system is connected with the details you have provided but I'm hoping this helps you look in the right place.
(Sorry to use "Answer" but I don't have enough rep to "Comment")
Jonathan
  • 354
What you call a router is probably just an ethernet switch, which means it doesn't matter whether you connect your Pi to the linux computer through it or using a direct cable. The linux computer can be configured as a DHCP server and NAT router for the Pi, I'm pretty sure this can be done using the network manager GUI so you don't have to tweak config files. Have a look at https://help.ubuntu.com/community/Internet/ConnectionSharing#GUI_Method_via_Network_Manager_.28Ubuntu_14.04.2C_16.04.29 as a starting point.
