Does Raspbian lite version use less cpu / memory than the full Raspbian. I know the lite uses less storage for sure but not sure on the cpu memory.
I am running some time critical code I am thinking might improve if I switch to Lite because the cpu is doing less of other stuff?
I am trying to capture 2 images simultanously. I have 2 pi zeros attached via usb otg to a pi3 and a simple python udp program that sends a message from pi3 to both pi zeros to capture. However I'm getting images up to 100ms apart.
jdonald
  • 2,972
  • 39
Lightsout
  • 429
Raspbian Lite doesn't have any GUI. It has only a command-line interface. If you want to work on Raspberry with Lite version then you should have a basic understanding of commands and file system of Linux. And Raspbian Lite uses less CPU and memory uses because of no GUI.
jdonald
  • 2,972
  • 39
Nikhil Jain
  • 115
Having more software installed doesn't have any impact on the CPU/RAM unless you run that software. Run raspi-config and disable desktop environment, and after a reboot you will get a system which will be pretty close to Raspbian Lite performance-wise. If that provides the performance boost you expect, you could permanently switch to Raspbian Line. I wouldn't hold my breath though.
Dmitry Grigoryev
  • 28,277
  • 54
  • 147
