I have a python script to log data from a USB weather station and present it via a flask front end. The USB on the pi (Pi2 model B) is flaky and occasionally hangs after 24-48 hours. The flask app doesn't seem to cope to well when my home broadband glitches out. To cope with both problems, I reboot the pi every night at 1 am through cron. I've also created an @reboot cron entry to run the python/flask app.
So, the problem I have is this:
  • If I run the script manually, it works perfectly every time
  • If I manually reboot with "shutdown -r now", it works perfectly every time
  • When the reboot runs though crontab, it consistently 100% of the time time fails to initialize the USB interface and usually without an error message. (Any error seen is a "timeout" which is semi-normal so ignored by the app. The flask front end still works fine.)
Is there something different about a cron-initiated script and the interaction with the USB subsystem?
Tried unsuccessfully: usbreset app, writing to "authorized" file for the USB device. They don't break anything but they don't fix the problem either.
pi is running Linux 4.19.27-v7+ #1206 SMP
crontab for the weather station user: (just one line)
@reboot bash /home/pi/wd >/home/pi/wdstartup.log 2>&1
crontab for root: (one line again)
0 1 * * * /sbin/shutdown -r now
the weather station startup script:
#!/bin/bash
cd ~pi
cd weatherd
./usbreset /dev/bus/usb/001/004
sudo echo 0 > /sys/bus/usb/devices/1-1.4/authorized
sudo echo 1 > /sys/bus/usb/devices/1-1.4/authorized
sleep 60
cp wd.log wd.log.old
nohup python3 weatherd.py >& wd.log &
cd ~pi
Steve Foster
  • 79
As I understand your question:
  1. You have a cron job to reboot your RPi every night at 01:00; e.g.
0 1 * * * sudo reboot (#or something similar; e.g. shutdown -r now)
  1. You have a 2nd cron job to restart your app using the @reboot facility in cron; e.g.
@reboot /path/to/your/flask/app
If you're certain that your 01:00 reboot is being executed successfully, then your flask app may not be running for one or both of the following reasons:
  1. You've not given cron a complete path specification for your flask app, and/or
  2. Your system hasn't initialized/started all of the services needed to run your flask app when cron runs it.
Here are some things that will help you get past the issues you've asked about:
  1. When you run a cron job, it runs as a different user - not you, in other words. That means the environment is different, and things like your $PATH may be incorrectly specified. That's a simple problem to overcome: Simply use a complete path specification to your flask app. For example:
@reboot /path/to/your/python /path/to/your/flask/app
  1. When you run a cron job @reboot, use the sleep command to give your system a bit more time to initialize the required services. For example:
@reboot /bin/sleep 30; /path/to/your/python /path/to/your/flask/app
  1. For reasons similar to those in #1. above, any output from stderr will be lost, which makes troubleshooting more difficult. That also is easily remedied; e.g.:
@reboot /bin/sleep 30; /path/to/your/python /path/to/your/flask/app  >> /home/pi/cronjoblog 2>&1
Which will append any stderr output to the file /home/pi/cronjoblog. If you want to write it somewhere else, simply substitute the file spec of your choosing.
Your question lacks a bit of detail that might have made it more clear. If this answer doesn't address the issues you're experiencing, please edit your question with the contents of your current crontab & anything else you feel may be relevant.
Seamus
  • 23,558
  • 83
