I want to use the VNC shipped with a Raspberry Pi. My goal is to offer the possibility to several users to connect to their own home at the same time. By default, I can connect to the "pi" user.
I have created 3 accounts "lary" "gary" and "hary". They have their own home : "/home/lary", "/home/gary" and "/home/hary". With a VNC client I would like to have "lary" being able to connect to the content of "/home/lary". Same for "gary" and "hary" at the same time.
Can I use ports for that ? Which files do I need to change ?
The default RealVNC installation shows the monitor screen, so it will show the display of whoever is using this.
You can start a virtual desktop and can run multiple instances.
The RealVNC documentation explains how to do this.
See https://www.raspberrypi.org/documentation/remote-access/vnc/README.md
To create and connect to a virtual desktop:
On your Raspberry Pi (using Terminal or via SSH), run vncserver. Make note of the IP address/display number that VNC Server will print to your Terminal (e.g. 192.167.5.149:1).
On the device you'll use to take control, enter this information into VNC Viewer.
It is also possible to create a systemd service to start vncserver instances.
https://raspberrypi.stackexchange.com/a/39374/8697 is a service I used with tightvncserver; this should also work with RealVNC (with minor changes for user)
Create Multiple Virtual Desktops
You can create multiple virtual desktops in Raspberry Pi by starting VNC Server on different display numbers. For example, to start a VNC server on display :1, :2, etc., use:
vncserver-virtual
Each time this command will start a new VNC session on a different virtual desktop.
Connect to Virtual Desktops
On your computer, open VNC Viewer and connect to your Raspberry Pi using the IP address followed by the display number. For example:
192.168.1.100:1 for the first virtual desktop 192.168.1.100:2 for the second virtual desktop To end a specific VNC session, use:
vncserver-virtual -kill :DISPLAY
For Example,
vncserver-virtual -kill :1
