Apologies if this seems straight forward but I've recently downloaded XFCE to replace LXDE environment.
I did this by using
sudo apt-get install xfce4
and following all the instructions.
Then to remove LXDE I carried out:
sudo apt-get --purge remove lxde
sudo apt-get clean
My problem lies that whenever I run
 startx
it still opens and runs LXDE? I know that I should be running
startxfce4
but I want to know how to completely remove LXDE? and understand how startx works?
Edit: Also how do I modify the startx file so that I can choose (if both are installed) which desktop environment I want startx to run?
Ghanima
  • 15,958
  • 65
gray_fox
  • 131
Follow the step-by-step guide provided by yours truly :-)
First install XFCE4 (consider also installing the xfce4-goodies package for extra visual candy)
Then list all installed LXDE-related apps
sudo dpkg --get-selections | grep "^lx"
...and remove them
sudo apt-get remove lxappearance lxde lxde-* lxinput lxmenu-data lxpanel lxpolkit lxrandr lxsession* lxsession lxshortcut lxtask lxterminal
Note that alongside lxterminal also pistore will be purged! So if you want the Pi Store, don't remove the lxterminal package
During removal the update-alternatives script will be executed and set xfce4 as the default x-session-manager in /usr/bin/x-session-manager.
Reboot the RPi, for the changes to take effect.
Last but not least you should run the autoremove and autoclean command to clean any unnecessary packages
sudo apt-get autoremove && sudo apt-get autoclean
And you're all set! Enjoy the much more user-friendly XFCE.
Gonik
  • 91
I posted this question in the Linux Stack Exchange as well, and a user named Vasa1 suggested to check
apt-cache show lxde
which listed all the associated packages with lxde, and therefore since lxde is a meta package, I therefore had to delete and remove the other associated packages in order to run startx to boot xfce4.
gray_fox
  • 131
