I am trying to set up a file sharing server on this here raspberry pi. The pi is running on Raspbian. I have it plugged in to my Google Wi-Fi router via Ethernet. SSH and ping are working fine, but when I try to install samba it is unable to connect to the server. I can connect to the Raspbian samba download server fine on my laptop.
Here is the apt-get output (note that I have already run sudo apt-get update):
pi@raspberrypi:~ $ sudo apt-get install samba samba-common-bin
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  attr ibverbs-providers libavahi-client3 libboost-atomic1.67.0
  libboost-iostreams1.67.0 libboost-regex1.67.0 libboost-system1.67.0
  libboost-thread1.67.0 libcephfs2 libcups2 libgfapi0 libgfrpc0 libgfxdr0
  libglusterfs0 libgpgme11 libibverbs1 libjansson4 libldb1 libnspr4 libnss3
  libpython2.7 librados2 libtdb1 libtevent0 python-crypto python-dnspython
  python-gpg python-ldb python-samba python-talloc python-tdb samba-common
  samba-dsdb-modules samba-libs samba-vfs-modules tdb-tools
Suggested packages:
  cups-common python-crypto-doc bind9 bind9utils ctdb ldb-tools ntp | chrony
  smbldap-tools ufw winbind heimdal-clients
The following NEW packages will be installed:
  samba-common samba-common-bin samba-dsdb-modules samba-libs
0 upgraded, 38 newly installed, 0 to remove and 7 not upgraded.
Need to get 8,978 kB/26.8 MB of archives.
After this operation, 101 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 http://raspbian.raspberrypi.org/raspbian buster/main armhf samba-libs armhf 2:4.9.5+dfsg-4
  404  Not Found [IP: 93.93.128.193 80]
Err:2 http://raspbian.raspberrypi.org/raspbian buster/main armhf python-samba armhf 2:4.9.5+dfsg-4
Err:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf samba-common all 2:4.9.5+dfsg-4
Err:4 http://raspbian.raspberrypi.org/raspbian buster/main armhf samba-common-bin armhf 2:4.9.5+dfsg-4
Err:5 http://raspbian.raspberrypi.org/raspbian buster/main armhf samba armhf 2:4.9.5+dfsg-4
Err:6 http://raspbian.raspberrypi.org/raspbian buster/main armhf samba-dsdb-modules armhf 2:4.9.5+dfsg-4
Err:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf samba-vfs-modules armhf 2:4.9.5+dfsg-4
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/samba-libs_4.9.5+dfsg-4_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/python-samba_4.9.5+dfsg-4_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/samba-common_4.9.5+dfsg-4_all.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/samba-common-bin_4.9.5+dfsg-4_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/samba_4.9.5+dfsg-4_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/samba-dsdb-modules_4.9.5+dfsg-4_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/samba/samba-vfs-modules_4.9.5+dfsg-4_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
My sources.list looks like this:
deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
# Uncomment line below then 'apt-get update' to enable 'apt-get source'
deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free
I uncommented that line and updated still no luck.
Update with information from comments:
I can successful ping raspbian.raspberrypi.org and also get html data with curl -L http://raspbian.raspberrypi.org/raspbian with one of the first lines <title>Index of /raspbian</title>.
Ingo
  • 42,961
  • 207
We have verified that you can connect to the default Raspbian repository. So it may be possible that your package manager has get confused. First comment the last line in /etc/apt/sources.list again. You will not need to use packages of the program sources.
You can try to reinitialize the package list files. How to do it look at Raspberry Pi sudo apt-get update not working. After that try to install samba again.
Ingo
  • 42,961
  • 207
I was getting the same thing and this worked for me.
Try running:
sudo apt update && sudo apt full-upgrade -y
Then install Samba as normal.
I got this from here
Run sudo apt-get update first.
Kate
  • 304
